Paul_13
[trackday_prep] Paul's Gti6
See how you get on, but with a helmet on I think you'll find the top of it is on the roof lining.
arnold naber
My cage builder has welded mines on the same height... im 2meters.. had to put the seat on the lowers mounting point to fit with helmet..
i dont have time to fix it now.. i'll do it in the winter but i would advice you to lower is..
Paul_13
I have no roof lining :(
I'll be going down there tomorrow and see how I get on.
Initially when I propped the seat up in position (roughly), it seemed ok.
Its got sliders on the rails and I have already lowered the seat mount on my side by about an inch+.
a 205 roof lining isn't very thick so it wont add much, with a helmet you'll be knocking the bar at the top of the door as you look sideways.
depends how long your legs are and how upright you sit too though.
Alan_M
I'm not far off your height Paul, and with a lid on I could touch the roofline cage bar quite easily on a Sparco Evo seat mounted onto the standard points.
I've just had my seat mounts lowered by cutting into the exhaust tunnel. Now my arse is about 2" off the floor and feels much better.
Paul_13
Had a bit of a look at the rails today, i've headed everyones advice about lowering the mounts.
I shifted the rail forward about 4" it seemed ok with the seat far back, but no chance of welding a bar for the rear rail inplace.
Plan is to chop the angle iron off the end of the rail and drop the rail by an inch, like so
Going out for a ride in kyepans MI hopefullly tomorrow :lol: Not the hairdressers mobile :ph34r:
Paul_13
I dropped the front rail an inch so the middle of the bar is resting on the exhaust tunnel pretty much and welded in the rear rail for the drivers side.
Haven't got round to the passenger rear rail of yet, as I didnt have time and was gradually building up a strong suntan.
Pic
Yay!
Alan_M
You'll find that to drop it low, the exhaust tunnel gets in the way pushing the seat out of alignment with the steering wheel.
Solution is to cut into the tunnel and weld new mounts in.
Paul_13
Cheers for the advice Alan, we centralised the seat in front of the wheel and it just fitted down the side of the exhaust tunnel.
Seats in a nice position now :rolleyes:
Took it for a test drive earlier... it's BL@@DY QUICK! :rolleyes:
Paul_13
MOT saturday! :)
Already fretting about it.
daveyboyblack
Just seen this Paul.... car's looking great! My Mi is back up and running after next week so gimme a pm if you wanna meet up? I'd like to have a nosey around a Gti6 engine'd car at some stage!
Paul_13
Yea can do Dave, another mate of mine has a GTI6 205 in red.
You may of seen him around...
gti-si
Good luck with the MOT Paul, don't fret. Mine passed today with no advisories <_<
Paul_13
Due to me being a dumb blonde, I realised that my 205 still had MOT till October and did not run out with the 6 months tax :)
If I had of known this I would of had it on the road weeeeeekkks ago.
It's on road now, already p!ssed off an M3 driver B)
Bit of a whirring and grinding noise, I think the whirring is the GB on the way out (done over 150,000!)
and the grinding I believe is the clutch bedding in.
I cant move this sh!t eatting grin off my face it's starting to hurt :D
Spiky
clutch should bind dude,
shame about the gearbox
and DOH! about the MOT.
as for your rev counter, have you checked you have plugged ALL the plugs in behind the dash?
Paul_13
Yep i've checked all the plugs behind the dash, check/moved the earth and had a quick look for the diode, but gave up.
I think the clutch pedal needs adjusting, it grips and all but makes a noise when I accelerate.
When I put the clutch down it stopped.
Its a new clutch I have in it.
Still cant believe how quick it is without flooring it :)
Spiky
could be the gearbox if it's quiet when you put the clutch in :)
there are 6 diodes on the loom B) if it's running, take an hours drive down here and i'll fix it :D
Paul_13
6! Blimey, might have to bribe you with some beer and take a trip down :D
6 sounds daunting, its far easier when you break it down though, one to earth, one from each pickup (i.e 4 coils), and one to the rev counter, easy :)
Spiky
no need to bribe me with beer tokens dude...lol
but easier to drive down then whip the loom off to send down :)
andyjstone
I cant move this sh!t eatting grin off my face it's starting to hurt B)
Could to hear it's on the road, I'll keep my out for you - mine is also back on the road now and I've been running it in a bit the past couple of weeks, taking it into to get the mapping checked on Monday so should be able to give it a blast after that - cover your ears over there :)
Paul_13
Finally got the car on the road today, had a drive around to bed everything in.
Met up with my mate in his 205 and got a few pics
A GT40 with 750BHP sounded like a animal <_<
On a worse note, the head gasket has gone :lol:
I suspected it when I first started the engine as there was loads of smoke pouring out the exhaust, but put it down to oil etc. in the exhaust burning off.
I was sat at the lights earlier and the idle dropped quite low and felt like it was running on three cylinders.
LOADS of smoke billowing out, then struggled to pull away then jumped(ish) to life higher up the rev range.
Would explain the water pressuring quickly and the loss of it earlier today.
I am going to pick up a head next weekend and already have a rebuild kit which I was planning to use on my 88mm crank conversion.
Going to change the stem seals on the new head.
My question is: if the head has come off a healthy engine, will I need to skim the head?
Very peed off at the moment!...
Edited by paul_xiii
Spiky
i had a HG go on my cossie, at 155mph :lol:
but the temp NEVER went over normal,
i even drove 4 hrs home,
as long as the temp never went mental, the head "should" be ok
AND it is removed corectky,
if it has got hot, or removed wrong it will need attention
bad news though <_<
Paul_13
It sounds like a sewing machine at the moment, I bought it off a member on the 306gti6 forum.
Sounds like a few of the valves are bent from reading a few topics on here.
I drove it home slowly and the temperature went into the red as I got home.
Think it would be best to replace the head altogether.
Hope that speed was on a track Spiky :lol:
Spiky
has it always sounded bad?
mine dont sound healthy, but they the exmanifold has cracked again..oops
if it's gone into the red, it may need attention
nope not on track...lol was playing with a mr 340 evo 8, i got past..lol nice little battle too :lol:
