Paul_13
[trackday_prep] Paul's Gti6
Paul_13
Ok cheers Spiky, wasn't slating you off or anything in the text above. Was in a temper tantrum last night :D
It's an ABS car so I was expecting something to be different.
I'm about to head over to my mates garage shortly and see how I get on :P
Spiky
no probs dude :P
dont help pug didnt stick to one system :(
multimetre is your friend, couple of mins with it, and you will get to the bottom of it :D
Paul_13
I'm borrowing my step dads £400 jobby :D
So i'm looking for switched lives and constant lives. I've printed off what people have replied with so hopefully it will be sorted :P
Spiky
on my loom
the thick red should be switch live
the thich blue is starter
thick white is fuel pump
i can send you pics of all the wires if you want them? so easy to know what wires do what on my loom?
Paul_13
If thats ok Spiky :D
That'd be fab!
Paul_13
Also is the fuel relay redundant now?
Paul_13
PM received Cheers spiky :D
Spiky
no 205 fuel relay
you now use the gti6's fuel relay, it's a double one near the ecu plug :D
if you take it off pin14 will go live with the ignition on :P (but only if you are sending a switched live down the loom)
Paul_13
Thought it was redundant, I was there for about hour last night looking for the damn plug lol :P
I'm off to go and give it a bash (with a BFH) :D
Just swap the Starter and switched live over, Early and late car's changed around 1991, easy as that
Paul_13
Just did that Miles to no avail... :lol:
Paul_13
I tested a few things with the multimeter tonight, I swapped the starter and live as Miles stated. Everything is how it should be but still no joy.
Thats how things are looking at the moment ^ Fuel pump turns on and the starter turns when it should.
I tested the double relay and pins 2, 8, 11, 14 and 15 all have voltage.
There's no spark and no fuel being injected, i'm not sure if the ecu is being powered up.
I've tried 2 ECU's now still no luck... :lol:
Is the CAS working OK?
Paul_13
Unsure what CAS stands for Miles, probably me being stupid :lol:
Paul_13
Crank alignment sensor? In which case it is present. (does this need setting up etc?)
Theres no fuel being injected and no spark which confuses me.
I've got sh!t luck if i've got 2 locked ecu's :lol:
Edited by paul_xiii
rubyna
Cant you check it with the ECU you had off of Anthony as that wouldnt be locked?.
Paul_13
Good idea batman, only problem is though it's my mates and if I lock it....
I'll have to get him a new one.
Does any one know for deffinate how they lock themselves, e.g. what has to be connected to the car (transponder)?
rubyna
It cant be locked now by using it the 205.
Edited by rubyna
Paul_13
I see, I'll have to give it a go.
Strange though because both ECU's were bought under the intention of them being unlocked.
I reckon it's something really stupid i'm missing here...
How is the ecu supplied with power?
Spiky
also looking at your looms, my looms were correct,
check you have the alternator wired on the alternator and the starter on the starter, between the brown connectors and the where the alternator/starter is in the bay :D
just incase you got them the wrong way around
also the constant live, you have connected that to the constant live of the starter or alternator? (the larger terminals) and not put it on the smaller terminals?
Edited by Spiky
Paul_13
Hi spiky,
Got a good feeling the double relays knackered, reading Smeghalls post it says; 'If the pumps on when the ignition is on, that proves the relays knackered'.
I bought it off Jonnie205 a while back says it all...
Right wanted thread next, unless you have one?
Paul
Spiky
have you got an inertis switch attached?
if not have you connected the wires together,
this is by the ecu and double relay plug
Paul_13
'also the constant live, you have connected that to the constant live of the starter or alternator? (the larger terminals) and not put it on the smaller terminals?'
The constant live I have placed on the larger terminals, is this ment to go on the smaller terminals?
My alternator only has a spade connector as a smaller terminal(?)
Inertia switch- wired them together last night, couldn't be arsed with the switch.
Edited by paul_xiii
Spiky
id not buy a second have double relay unless i "knew" it did work
i not sure if i got any spares, will have a look
it's meant to go on the constant live (battery cable) the larger of the two :D
you still havent got the bottom of why the starter is getting live at notch 2 and not notch 3,
check and make sure you have conencted the wires up correctly :D
Edited by Spiky
