Paul_13
[trackday_prep] Paul's Gti6
cheesegrater
I'm more concerned by this...
Paul_13
:lol: That was when I was working at Brighton lad I was working with had the pass card for the door. It's one of their mascot outfits lol.
Fitted the front leathers to the GRD earlier :) Front seat bolts on 5 door subframes are a bastard!
Edited by Paul_13
allye
I bloody hate those front bolts! You can't fit a ratchet torx in there so end up using torx key and turning those super long bolts 1/3 of a turn at a time <_<
Paul_13
I was out doing them for an hour! I cheated in the end and used to shorter bolts that were holding the subframes to the old seat :) Still a bastard of a job!
cheesegrater
You need that teng tool I have for them!
Paul_13
:lol: I was actually thinking of driving round to my Dad's with no seat to borrow the same tool :D
Paul_13
Did some more
Xsara crownwheel with 205 diff in place
Diff cover
VSS sensor modified as it fouled on the gearbox, couldn't get the plug on
Gearbox done :)
Photo for reference
Engine bay on the weekend
Edited by Paul_13
Paul_13
Changed the top mounts for OE items (cheers Cheesegrater for picking those up :))
Wiring routed through into the cabin
How it looks now
And removed the grp a fork bushe, to be replaced with a brand new OE bushe
Paul_13
Bit more
Where the engine management light would be.
Wire on the car side of the loom 74a. It works now :)
What the 6 pin plug looks like
Inlet on (for the 100th time)
Moved the air filter into the engine bay, see if the straighter run to the throttle body makes a difference
This little bugger was stuck in the air filter
Moved the shunt box to a more solid mounting that doesn't involve cable ties
Had a real worry earlier... Started it up and it was misfiring like fook. Checked the plugs going to the injectors and coils, all fine!?
Took the spark plug out, again looked normal. Changed the coilpacks about as cylinder 1 wasn't firing and it was exactly the same?!
Checked the earth etc, and was fine.
Changed the ecu over to another I have and it went back to normal!
Changed the ecu again to the old one and it's fixed! Well confused on that one.
Also discovered there's a dodgy earth connection on the front end.
Jobs for tomorrow:
Remove struts and soften shocks.
Fit driveshafts and gearbox oil.
Do up hub nuts
Fit wishbone and new bolts
Tighten up wishbone bolts on the floor
Buy a mini filter from halfords and jubilees
Change harnesses
Fit dash plastics
Bash heatshield so it's not rubbing on exhaust manifold
Bleed coolant
Change indicator
Measure seats
Fit engine fork
Sand off brake pads
Check speedo cable
Find a new fan switch plug
Drive :)
Got to post this on here, What did you do on your old box, it was pretty much on it's last legs, :lol: , Sun & Planet gears where ready to strip, 5th gear had a tooth missing so you did well,
Also it wasn't a Xsara box, a S16/405 box
Paul_13
Ahh... I was told it was a low mileage box when I bought it and I helped take it off the Xsara, so they were none the wiser.
That's pissed me off a bit
cybernck
They knew you were going to destroy it anyway ;):lol:.
Paul_13
Do up hub nuts
Change harnesses
Fit dash plastics
Bleed coolant
Change indicator
Measure seats
Fit engine fork
Sand off brake pads
Check speedo cable
Take rear 6x9's out and put other rear cards in
Fit strut brace
Strip down old beam
Insulate starter wire I cut out! I know i'll forget this
Buy 5.1 brake fluid in the morning
Change wiper blades and source some twin jets.
Drive :)
Nearly there, ended up sticking the 307 HDI brakes back on so the 266mm setup is for sale.
Edited by Paul_13
Paul_13
Do up hub nuts
Change harnesses
Fit dash plastics
Bleed coolant
Change indicator
Measure seats
Fit engine fork
Sand off brake pads
Check speedo cable
Fit strut brace
Strip down old beam
Drive :)
All done with Tom's help today :)
Just a few bits to do now
twin jets are cheap from pug :) (standard on the later 205 and same part as 306's)
Paul_13
01
6438 71
02
WDW WASHER JET
TWIN JETS
I found something!
Edited by Paul_13
Paul_13
ICV filter fitted
The autofactor sold me a 309 driveshaft in a 205 box by accident :( it was bunching up pretty bad and sending vibrations through the car.
Quickly put a spare inner cv cup in before too much fluid leaked out, saves buying another tub as I have half of one spare :)
If you jack that side of the car right up in the air as high as you can, you can swap that shaft without losing any box oil.
I know this as I had to do it outside the guest house in Germany when the useless bastards sold me a "205" short shaft that was too bloody long as well. Sadly it only caused a problem when being driven in anger around the 'ring, when the NSF suspension was compressed.
Paul_13
Thanks for the tip Tom
Paul_13
Put the shaft in earlier and fits now :)
Going to take it for a quick spin tomorrow
Strictly_Derv
Are you taking this too pick the seats up at the weekend?
Gman
back from the honeymoon now mate, so if you need any help with anything (not that I know what to do but can hold spanners and s*it), just give me a bell and I'll come over
Paul_13
^ Cheers Gman
Had the MOT on the dieasel today and it passed :)
Managed to get the door to open, turned out it was the lever on the back of the handle was seized. Bit of WD40 and 5 mins of working it and now it's free :)
Wheel swap :)
Quite like the reversal :)
Also stripped down the 205 beam I have spare, inner bearings were a c*nt to get out! Just got to remove the bushes next done 2 of them just the other half to go.
Took the Gti out for a proper drive earlier, annoyingly 4th gear syncro is buggered :angry:!
FFS - you really don't have any luck do you! :(
4th seems an unusual synchro to be knackered though - normally seems to be 2nd/3rd that get abused.
At least the diseasal has a fresh ticket on it though.
Paul_13
Nope... I'll let you drive it tomorrow if I bring it round, so I know i'm not going mad :lol:
