Paul_13
[trackday_prep] Paul's Gti6
SurGie
Coming along well now Paul, alloys look superb !
Paul_13
Did you find that pic you were looking for George?
SurGie
Yes thanks, it was a few pages back.
Paul_13
Another product to fail the accredited Paul_13 testing program
Anthony is a f***ing legend by the way, after a long day and driving to my Dad's house in Bristol (for work the next morning) I noticed the exhaust got suddenly louder and rattled like f***. Got steadily worse and after a quick look under the car I thought the clamp had come loose.
Anthony offered me hospitality at his for the night and have a look at the back box in the morning.
Before I'd even got out the house I was met by bad news as Anthony already has his head under the car (the massive crack in the back box!) Being in a bit of a dilemma as I needed to get to the induction on my new site and didn't want the back box to fall off on the M4/M5, Anthony lent me his trustworthy HDI. And Anthony driving my GTI to his work and sourcing a replacement back box while I was in Bristol.
Unfortunately the M4 was shut and Anthony had to drive through quiet villages with a car that sounded like a "can am V8". Recieving a text later that morning that actually made me cry with laughter:
"The definition of anti social? M4 being closed and having to drive through sleepy villages at 7.30am. The looks I got... you'd think I'd just s*it on their dog"
Your a legend mate :)
Edited by Paul_13
Paul_13
Next job is to fit the Xsara VTS PAS setup I bought of AlastairH. Should transform the car :)
Also i've fitted a brand new MAF sensor, ECU temp and Lambda and it seems to run a lot smoother.
Speedo died a week ago which i'm not happy about. I've checked the cable, clocks, cogs,... everything is fine so i'm a bit baffled. Couldn't fully see if the cog in the box was fine as the gearbox oil was above the level of the cog. So next job is to replace the cogs. Joy
Got rid of the Group N top mount rubbers and the car is more civilised on the road. Doesn't tram line half as much and turns in better.
Fitted the 1155 mintex pads and the results are good :) Good cold bite and sustained hot bite
1.6 GTI box is a hoot :D Really revvy and goes well, really well. Bit of traffic light GP with my mates 306 Rallye, and the 205 was miles ahead :ph34r:
Edited by Paul_13
allye
I had a lot of fun with my speedo, it was never the clock end that was the problem. Some cables can push in at the gearbox end and not engage which was my problem.
Paul_13
Started fitting the PAS setup, changed the engine mount over and fitted the rallye pulley setup.
Bit tight but just enough room :)
Pump fitted and belt aswell, what a bastard of a job to get the belt on!
Heated the pipe up with a heat gun and turned it round to face the inner wing
Paul_13
Bottle wedged in the wing, will figure a way of securing it later. Also trimmed the pipe to make it fit between the pump and bottle.
For the other pipe I used the rubber one supplied and cut a section out of the loop to join the return pipe from the rack
High pressure pipe attached and routed down past the block and under the sump. Inlet also on and the fuel pipes clear everything.
Hehe
Paul_13
Everything back together
Interestingly only 10mm difference in pinion height (205 square drive NON PAS vs Xsara PAS rack)
Edited by Paul_13
Doh, not a vts rack, maybe a gti6 one? Think standard ones are even more turns.
Paul_13
Either a 6 rack or a standard xsara rack at my guess
Paul_13
Curiousity kills the cat so they say.
Changed the rack on my mates GTI6 which had an alarming amount of play in one of the inner joints.
I was curious how the NS arm came off the rack, couldn't see how the gaitors came off. I know someone was asking this question recently on how to remove the arms off a xsara rack which is the same rack.
There's a metal collar which is built into the outer gaitor, one hit with a flat blade screwdriver and hammer and it freed it off. When this is pulled back you can use some stilsons to crack off and unscrew the track arm.
The inner gaitor had enough give in it to slide it over the PAS ram stud, couldn't work out how to remove the stud mount. must be pressed on.
Also compared a Xsara VTS ram to a GTI6 ram and they are the same. Same dimensions etc. Odd... so i don't know how the lock is limited on a 6 rack.
Miles came to the rescue with a Xsara VTS rack that he's lent me, didn't have a ram or pipework on it so I pinched the pipes off the 6 rack I disassembled earlier. Kyepan came to the rescue with a ram :)
the ram limits the lock, if you compare the fully extended length you will see the VTS ram will go further, fully compressed will be the same.
Paul_13
It was exactly the same length unless i wasn't pulling on it hard enough. I'm pretty sure I did extend both fully.
Is that from what you've experienced or heard?
Hang on. That rack came off Hovis's rallye so could be anything... considering the engine was 'cammed' and came from a well respected company and half the other shocking work done on the car could warrant it being a different rack
Have you got any pictures of the 2 next to each other?
No pics I'm afraid, that was from doing AdamB's 306 V6 and he thought it'd be great to swap the ram so he could actually turn right given the gearbox wasnt in the way any more :D
Retained the original rack as it was still good, fitted a few new boots and the standard 5 speed ram.
Could well have already been a 5 speed ram on Hovis's car, seems to have had a hell of a history that car!
Paul_13
Yep... We figured out where the 'R' cam came from on the group buy. The 'cammed' engine was fitted by a localish company. You might of seen the pics in the project thread.
Tomorrows job is to
Fit the rack, fill it with fluid.
Tracking
Fit new back box
Fit xsara rear shocks (for time being)
Fit rear discs.
Take it for a test drive :)
And some point dry the car out!
Edited by Paul_13
So a nice local firm popped some R cams into an RS?
Nice! :D
Sexy! B)
Gman
What you upto now Paul? Bodies?
Paul_13
Not quite
As Anthony would say "it's been working too long ;)"
On a serious note its the petert cams I'm fitting
Edited by Paul_13
