acox99
iPlod999
Worth checking.
When I took the holder out the water appeared at the sunroof handle end.
However, there is no water on the handle or no obvious drips within the roof.
I will at least wrap the receiver in a sealed plastic bag.
Tamanga
Checked and thankfully it's dry but the next time we get a dry day I'll be adding a dab of PU sealant to be safe!
Hope you trace the leak bud.
Daviewonder
Rubbed down my tailgate as it has lacquer peel.
Fitted new fuel pipe clips and hard fuel pipes underneath
56F89EF5-6DAC-46E5-A53C-B8742BE3D10A_zps
Daviewonder
You can't give an update like that and use the same photo as last time :P
Damn you and your Team manager powers ;)
Edited by Daviewonder
Copy and paste failure on my part!
allanallen
As if you'll ever dare drive that you perv! :P
Juttie205
Are the new fuel clips still available through peugeot?
Yes, not expensive either, 80p each or something like that, you need 6 but they come individually.
Juttie205
Thats great do you know if you can get brake pipe clips aswell?
iPlod999
Found the wire for my oil temperature gauge.
It was plugged into the water temperature warning light. Swapped it onto the water temperature sensor and up went the oil temp gauge on the dash.
Happy days!
Cut it, found a length of cable and connected it to the sensor on the sump.
Then nothing. Went for a blast up the local A road and the needle did not move a single millimetre.
Bugger!
chipstick
Started it for the first time in 6 months. Fired up first time :) (after cranking it to build up oil pressure obviously)
How far did you go? It can take a long time of sustained high speed to start moving.
iPlod999
Drove it for and hour so before the 'fix'.
Once connected ragged it for about 20 mind. Not a flicker.
I'll leave and see how I go on a longer run.
Although, I doubt my crimper skills are as good as yours Kieran. ;)
oonip
Have you painted those hardlines? If so what's best to use?
Luke
Put my new gear gaiter on backwards... <_<
Edited by Luke
20 mins probably isn't long enough TBH. However if it is totally dead feel free to come over some time and I'll get to the bottom of it...
iPlod999
I will attach the new wire I have put on back to the water temperature sensor.
That will show if I have crimped ok.
If there is still no movement it may mean dead sensor in the sump.
I'll keep the offer in mind Kieran.
Cheers.
No, thats how the new pipe comes from Peugeot, with a kind of black plastic coating on it.
gruffa
My new axle stands came today so got it up on them and tucked my wheels away out of sight, grinded all the rust spots out the boot and started to dismantle the front susspension ^_^
Wes
ragged it around castle combe :D
james_pug
Picked my dimma up from being in storage for the last 2 and a half years
EA893AFF-FC9A-4DE6-89D2-A434507FA729_zps
2CC3A441-11FC-4CEA-9324-35C012F25A81_zps
  • Like 3
chipstick
Taxed and tested after hibernation.
After driving practical, comfortable cars for several months it's made me realise how bad the road surfaces are out there :lol:
I was soon reminded how much attention the car attracts from people trying to push you on or attempt a traffic light Grand Prix.
Reebmit
Started to remove rear beam on one and started rebuilding a head for the 1600...... :)
rallyeash
Snap!
