acox99
chris 417 mi
21 minutes ago, Tom Fenton said:
I’m busy with this at the moment. I should probably write a thread about it, I miss build threads these days.
No engine or gearbox in at the moment, but having fitted the tyres to the wheels I wanted to see what they looked like on the car.
Start one, its nice to see a thread with people still doing them on here !
Ill be starting one soon for the miami  shell i rescued two years ago :)
ScoobyJawa
5 hours ago, Tom Fenton said:
I've done a lot of 205 8v timing belts, assuming nothing goes amiss its 3 to 4 hours work start to finish to do the belt and water pump, bleed the coolant and run up, etc. But, that is to me that is very familiar, to someone who has never done one and is feeling their way through the job, it would easily take them longer, some of the belt cover fixings are difficult to see, you have to feel for them, and the spring loaded tensioner is a simple and clever system once you are familiar with it, but to someone who has never done one before, could understandably take some head scratching to figure out what the hell is going on.
Thanks Tom, they charged for 4.5 hours so its about right, as I did ask them to check around for any leaks elsewhere that may need attention while it was on the ramps.  They are my trusted garage tho, had really bad experiences taking it anywhere else, and they've known the car 20 years :)  They were originally Peugeot/Citroen specialists and while they do all cars now, they still have a large amount of older stuff in the shop vs newer cars, and its still the same chap running it.
Edited by ScoobyJawa
As said it’s about right then. It does take that long tbh. Getting the covers off is a job in itself, and your arms usually bear the brunt of being scraped on various things.
28hodge
i also did a cam belt change on mine today, then paid the entry for it to go do the RAC in November, so i best get it put back together properly!!
stef205
I mated some VW junk to the engine.
  • Like 3
ScoobyJawa
Had the longest journey in years. Down to Beaulieu for Simply French. Ran really well, even with shocking weather on the way home.
great day out but I think the weather forecast kept others at bay, not that many 80’s/early 90’s
On Sunday, local car show. Centre caps for the wheels have been fitted, I wasn’t sure at first, but think I do like them.
Leslie green
Drove 120 miles today , a crow swooped across above me  then turned sharply as I was driving and dropped what looked like a small apple right into my path which hit the windscreen at 50 mph , it didn't explode so  it was pretty hard and bounced on the road behind ,made a right thud but luckily missed any panels ! then went home washed the car and 20 mins later another bird had sh*t on the bonnet lol
barneys66
Picked the worst day of the year to drag this around..
Drove about as a course car for my motor clubs Historic daytime road rally for the day, with COC on the side of the car, seems right I suppose!
  • Haha 1
Rebushing some Bilstein fixed platform damper bodies. 3 hours to make the tooling that I’ll probably never use again, I knew all those scrap trailing arm shafts would come in handy one day, 30min to do the job.
They were intended as spares for my road rally car, but I might fit them to my grey car actually.
Richie-Van-GTi
Investigated a drip on the PAS, found 2 leaky PAS pipes, a broken jubilee on the radiator top hose causing a coolant leak, a drip on the gearbox sump plug and a leaky engine sump.
All easy fixes, but bloody annoying.
Those two small HP pipes are prone to cracking, when the ram bushes fail.
Competed in my motor club 12 car road rally last night, and won it. Good little car.
  • Thanks 1
Pierre_b
I have started the be3 conversion I was postponing for years. Today, I took out the drive shafts, I dont know how many month the car will stay up in thé air....
Pierre_b
This morning, a few moment of wrenching on the be3 conversion. I have three "rods" between thé Gear linkage and the be1 gear box, it seems that a won t bé able to fit the smaller one.
I took out the old megasquirt harness that I built a long time ago to add the crank sensor, the wastegate actuator and the idle valve control, and ev14 connectors for the injectors.
I also tried the "tools" that I printed to fit with little bit a protusion (?) the drive shafts gaskets :
Pierre_b
The conversion is moving slowly, I have unbolted the starter motor, and made some room on the top of the engine th weekend.
Gohn
what no mudflaps Tom ?
nice car
great wheels (are they Oz or compomotive ?)
well done
chris 417 mi
Posted (edited)
Washed & Taxed the Laser for her first outing this Sunday just gone, then made a mental list of jobs to sort id noticed on the runout  :D
IMG_6186.thumb.jpeg.685c1483fe9f27c4de5a472436f3748b.jpegIMG_6190.thumb.jpeg.6ae607d47de308abe01e9ff9c7836eb0.jpeg
Edited by chris 417 mi
a few weeks back, hacked away the Budlia and brambles that were trying to take over the 205, pumped the tyres up, jacked up the back end and gave the temporary steels a whack to free off the brakes and made sure it still rolls.
made a mental note of the state of the bodyshell, ordered a bunch of parts from Arie Pronk in The Netherlands, had them Delivered to Hilgie as George and Dan were going over the week after B)
time marches on, its been 13 years since it last saw the road :blink:
recently lost use of the barn I shared with Dan and  few others so that's put a dampener on my ideas for a bit :angry:
I have been busy polishing a turd/making the best of what I have got. Nearly every panel has a mark dent defect or rust bubble of some sort. Jury is out as to whether to do anything with it or not, it will undoubtedly end up being a total strip and respray and I’m not sure I want to go to that length.
Anyway some time with a 3 in 1 polish and the da polisher and it’s certainly looking ok for what it is.
I also got brave with a scratch across the rear 1/4 to the tailgate at bike handlebar height that my daughter insists was definitely, 100% couldn’t have been, absolutely not possible, was not her……
Flatted it and it polished out ok, so I’m pleased with that.
  • Haha 3
Leslie green
Drove this for 5 hours today and 205 and a bit miles was covered on many twisty roads on the way to the biggest carshow in europe Kilbroney Northern Ireland .
ScoobyJawa
Posted (edited)
New proper sized boots last week after being on 195 50 15 for eons.
Trip to Beaulieu Motor Museum for Simply French. 3 hour round trip, behaved really well, shame I don’t have air con though - phew!
Better turn out than last year as better weather!
AlexRS2782
Ticked past 128k on a mini run earlier in the week.  The present for that milestone has been for the car to develop a new set of issues including no power to the stereo or any of the buttons above (hazards and rear fog not working so assume the rear screen demist is gone too).  Clock and fag lighter still working.  So obviously new elec gremlins in there somewhere.
Engine has also started burning oil more than it ever did before in my ownership so currently working towards getting it into Miles at some point to get the engine rebuilt (major service including the belt was due anyway, plus i think the gasket on the exhaust manifold looks like it's started leaking based on the smell in the bay) and at the same time clean / tidy the engine bay of rust, etc, repair / replace various bits of the loom, etc, as it all needed doing anyway.
