Matt180
[project] 205 Gti 180 Track Car
Schumi
Yep. Wiseco offer 8.5 and Wossner offer 8.3 compression ratio for forced induction system. I dont wanna go to low like that. I'm thinking to custom made to wiseco with 10:1.
Which brand are you thinking.
Matt180
CP pistons from america have been oredered. Keeping the standard ew10j4s comp (11:1)
guffe
Right on! No low compression slug, high compression with proper engine management is the only way to go.
johniban
Will you not gain any performance benifits keeping the same compression?
Matt180
With higher comp you should get more power with less boost. I was running standard comp before so will be exactly the same, only now ill be running a bit more boost.
johniban
is it safe to run more compression with boost? i always thought you had to use low comp pistons with a turbo build
alexcrosse
depends what fuel you use, how much boost you use, what plugs you use, how well you can control spark fuel and boost with the management, inlet temperatures, etc etc. Ideally you want to run the absolute highest CR you can for you desired power, just on the edge of det.
VW 2.0 TFSI as an example runs 11-1, though that is direct injection and modern management, so has a far higher degree of control.
MiniGibbo
Bummer about the engine, remember watching this at FCS.
Sure it'll be better than before when it's back on the road.
Matt180
As said by Alex and confirmed by Welshpug, high compression and boost work very well. If i was to lower the comp i'd need more boost to make the same power. It would more than likely be gutless low down as well.
Matt180
Update time!
Ill let the pictures do the talking. Its taken a long time getting this done, all that's left is some testing to try out different spring rates. I'm currently running 400lb at the rear and 500lb upfront but I have plenty to choose from. The forged engine build is taking a little longer than we expected so I have fitted another standard lump for now. Its not something to be rushed and it'll be worth the wait :D
577497_10151901793053989_785316146_n_zps
941830_10151901794433989_1677406435_n_zp
264573_10151941622228989_1012427682_n_zp
941851_10151901793383989_1508062103_n_zp
262384_10151901793488989_929192141_n_zps
575465_10151901793723989_134166740_n_zps
580437_10151941622343989_2011748152_n_zp
946630_10151941622588989_798045739_n_zps
Spiky
ooooohhhh niiiiice
love it :)
hope those dampers are up to it!
Matt180
Any reasons why they wouldn't be?. Certainly do a good job on westfields/caterhams etc
Spiky
They should be ok, protect the adjusters as they tend to seize
EdCherry
Do they?
Matt180
The ones I have seen aren't to shy around corners yes!. I'm not in a position to be spending 1k+ on top end shocks so these will do for now.
Matt180
500lb Nitron shocks for the front
970609_10151941622528989_176738852_n_zps
5A52ACCC-DC72-42EE-9C9D-FCAA436B1BC0-940
6111E091-2CD3-4DB6-B9D4-9B526D68722B-940
64AB5EC3-D19E-435C-90CA-D72F6A502E09-940
E4000F48-51B9-4052-8C2F-58735C854D80-940
951101F6-E31D-4002-8214-C31EB26F6717-940
06B8AFE6-9817-4D7B-BB70-632F9D8440BD-940
D402277D-CAD7-4C37-8650-CFBC5D431051-940
675EDC78-4308-43A6-BE26-9317BC567265-940
2052NV
BOSSSSS! that is a wicked project. Very keen to do inderpendent rear in mine. Did you just ditch the factory torsion bars and keep the ARB?
Matt180
Its not independent more like semi-independent.
Yes i have totally removed the torsion bars and ARB. Shouldn't need that with the spring rate i'm using.
What holds your trailing arms on??
Std setup is independent, its not a golf!
2052NV
ya know close enough/ you know what mean :blush:
allanallen
Very nice Matt
calvinhorse
Work of art! Looks awesome :)
Edit- and lads, don't turn this into another 'I know more about suspension than you do' thread, everyone's sick of it.
Edited by calvinhorse
  • Like 4
Matt180
What holds your trailing on?
The trailing arms have been machined on the inside to accept a side contact bearing. A shaft runs down the beam tube which is tapped at each end. Then its just bolted through the bearing to load them up.
Not weigh the torsion bars and ARB but i have saved a lot of weight too which is a bonus!
