alexcrosse
[race_prep] 205 1.9 8V Hillclimb Car
edbar
Nice! What cam are you running? 285?
... popped off the dizzy and saw it was a piper 270 deg cam, which was a nice surprise
edbar
Doh! That will teach me for not reviewing previous posts!
alexcrosse
Yep., 270 lol.
Got the exhaust today
massive thanks to matt holley! probably the smoothest sale ever, no hassle at all :)
It will be enough for this engine I think, and something else I dont have to worry about!
Cheers,
Al
Matt Holley
I'm glad it got there ok, I did worry the weather would mess up the delivery.
alexcrosse
Yer I thought that! usually my luck but great job :) thanks again pal, maybe see you at some events later in the year?
alexcrosse
oh haiiii, engine is now all built up and timed in. Just sorting out the blanking plate for the distributor and the trigger wheel, but that shouldnt slow the progress of actually getting it in. Its looking good though, cleaned up the gearbox alot last night too but no pics of that!
Anyway,
Cheers,
Al
Cameron
Nice colour choice. :D
Also liking the starter motor engine prop, but you should really use hammers for that job. ^_^
alexcrosse
Cheers :) Pimp my engine. Starter motor seems to work pretty well, almost seems a shame to fit it to the car! There is piece of wood there too, all the mod cons!
could be an XU7 or XUD item :)
alexcrosse
I meant works well as an engine stand... but yer, its not standard, just came with the engine, looks buff, itll do.
Cameron
Was just wondering cos if it wasn't I have a spare XU10 starter you could have for Carrrrrrrlll.. looks like one though.
Use a complete late XU7/XU10 8v thermostat housing in place of the 205 one, as that will act as a blank for the dizzy, and give you an OE solution to attach the coilpack to and thus no messing around making up brackets/mounts.
alexcrosse
cheers, but too late, lol, got a distributor plug made up at work, should be done today.
alexcrosse
Dizzy plug is all done, was turned from a big old bit like so...
Then sides milled to suit, aqua blasted, full case aqua blasted, then o-ring fitted with some rubber grease. Tight fit, so should be perfect :)
More progress tonight, might even start pinning the wiring loom on the wall much later on :)
Cheers,
Al
have you seen the non-dizzy housing? gives you a nice place to bolt a factory coilpack on, so youi can use standard leads etc
alexcrosse
yep, anthony already mentioned it on the previous page, but already had the plug made up, hasn't cost my anything anyway! lol, and its all clean and pretty now...
alexcrosse
engine should be in soon....
cybernck
Where's the lower engine mount? Or do you have that one already?
alexcrosse
on its way.........
alexcrosse
ok... got some done today while nursing the latest hang over.
clutch on
gearbox on
starter and bits on
shaft and housing on with new mount
welder completely shagged itself today, feed is all over the place because a little tube inside has expired :(
annoyances
but managed to make a new mount with it... dr pepper hey
finished and in primer ready for dropping in the engine tomorrow :)
cheeeeeers :) Al
alexcrosse
oh haiii.
Ok, got the final bits done to get the engine in today, BBM mounts on, nom.
Trial fitted the manifold
which went really well... until one of the studs snapped inside the head. I very calmly said "oh, what a pity" and managed to drill and extract it with no damage or pesky swarf anywhere.
chucked some white on the shonky gearbox mount
dropped it in (i will clean the sump... the inside is clean thats what counts!) and rude trumpets on, no spacers yet though...
and one for the wank bank
Cheers :) Al
Edited by alexcrosse
alexcrosse
went to proalloy yesturday so ordered a custom rad while I was there :)
