alexcrosse
[race_prep] 205 1.9 8V Hillclimb Car
Me too! Coming along nicely Alex! Roper is meant to be a bit of a legend, i might nab his contact details for future use if you would. :)
Where did you get those cams? That one is huuuge! :o
gotta be 300+ those surely :lol:
alexcrosse
Yep, decided im porting it myself (hence the flow bench), but roper will replace and cut the seats for me... I like to do as much as I can myself which is a downfall really, LOL.
I got the cams from a chap at work, he built a few hotrod 205 engines years ago which made nice power (240) and had a few prototype cams from piper taking up space... next couple of days and ill no about cam duration. Ive got a feeling they are around 328 degrees, but im going to measure them all and then pick the lowest duration I think... they are all different as they were supplied to allow him to find the optimum for his application. But the lowest im sure will still be wayyyy over 300 degrees :) lol.
Cheers,
Al
Edited by alexcrosse
TT205
Are you after a tiny tiny powerband then? :lol:
Make sure you use the right oil for those cams or the buckets die, And not wanting to put a downer on things but I've known more than one of those Piper cam's to snap in half too so might be worth X raying to check it first.
alexcrosse
Cheers for the advice miles didnt think of that! ill check to see what they ran in the race engines at work, you got any recommendations? The chap tested a lot of these cams with piper and had no failures, so I'm fairly confident, but I will have a word and see what he thinks.
Picks of the shonky flow bench to come tomorrow. Also got some sort of suspension sorted which is a weight off my mind!
Cheers,
Al
alexcrosse
Manometer up
I like
Burrs came for ripping meat out heads :)
Cheers,
Al
Cannot recall now, but with a oil from Sunoco,
alexcrosse
Ok, took the meat out the head to let the cam rotate tonight, which took a while...
then several hours, alot of tipex and putting the cam in and out and...
Will smooth out tomorrow after cam measuring excitement, lol.
Cheers,
Al
No egg sucking, but the easiest way to check a cam is with a pair of v blocks and a dti on a steel top bench, you can then relieve the head to suit the cam you intend to use ;)
alexcrosse
similar cams, only slightly different so they all fit now. Its a complete ball ache measuring cams like that, just rotating a cam and measuring straight off the lobe will push the DTI to the side, much better to do it in a head to measure duration.
Cheers,
Al
alexcrosse
bad pic, but much better, and some yokes
Also got the pedal box off ready for some fab next week.
alexcrosse
So decided bias pedal boxes were a rip off so have started making one.
boss welded in for bias bar
brake pedal done
yawn
in the box with the back cut out ready to weld in 2mm rear plate to close original hole and then the spreader plate for the masters.
sorry for the rubbish pics, phone battery was low so didnt have a flash for half of em.
Cheers,
Al
alexcrosse
got the plate in the pedal box and welded in
Cheers,
Al
lemmingzappa
Good to see you on here Alex, keep it up :)
willo-1
great project looking forward to more updates...,
alexcrosse
cheers willo, been busy moving house sadly, so not too much done, finished the fab on the pedal box last night but forgot to take pics, also sorted out some second hand coil overs, mounts, rear damper and uprights for it. So will be building up a new rolling front subframe over the next week, hopefully thatll be in next weekend with any luck...
alexcrosse
got the smallest amount done over the last couple of days, but its been cold, and ive been miserable so progress is limited
Pedal box body done and painted
disassembled and cleaned up the top caps and seats for the coil overs
same with the top mounts
cleaning up the uprights next week and painting them, then hopefully bolt together the front subframe at some point next weekend (best case).
just want to aim to get the front on its propper suspension now.
Al
Cameron
Oooo they cleaned up nicely! :D
Should have left the engine bay pink too. :lol:
Sexy pedal box!! :wub:
alexcrosse
haha, cheers cam, ill let you no when ive finished getting all the surface rust off the dampers in about 9 weeks =p LOL
Not exactly my best welding Baz but itll do for what it is, just needs to not break when I brake! lol
Cameron
Yeah have fun with that! :lol:
What the hell happened to your mate's hand btw? Looked like some pretty savage blistering! :o
alexcrosse
oh i will dude, literally cant wait!
the story begins "after a few drinks we were standing in a bonfire when.... " lol
alexcrosse
How do... Got a bit done this weekend, picked up another subframe so I could do a straight swap and save time rather than cleaning up my own
doner subframe stripped and cleaned
seam welded in places that I thought it could do with...
primed
painted
springs and 309 arms also painted
alexcrosse
out with the old
ready for the new...
coil overs cleaned and built up
arb brackets got a paint too along with the bar
all bits cleaned up ready for assembly
poly bushes pressed in and arms on
arb in with poly bushes and car dropped onto subframe
hubs on... do need to clean a bit though!
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/305795_10150409841599330_509954329_8374507_1295606692_n.jpg[/img]
all on :)
oh, and built up the pedal box
just need to sort out what im doing with brakes and source a quick rack for it now and thats the front suspension done, can move onto the back
Cheers,
Al
