Jackman
[car_overhaul] Yellow 205 Rallye..
Jackman
it isnt fast at the moment, missing an engine :angry:
It'll have and engine by this weekend, Daniel!
Just a small update!
Did intend to smash the car this weekend, but i've gotta go to France with work now, so thats all out the window! Plus the weather is s*ite!
Had a few bits sprayed up by my friend Matt @ Spraytek!
Engine mount, Gloss black to tie up with a few other bits!
And my coilpack cover on my new JP4 Rockers
I get back from France Wednesday, so hopefully a few bits i'm waiting for will have turned up and the engine can go back in next weekend!
Jackman
Quick update from yesterdays progress.
Wolze kindly came round and slapped the car back togeather in the time we had!
Intention was to fit the engine, but we didn't realise how much we had to do to get all the subframe back togeather and on!
After a trip to the nuts and bolt shop we were ready to rock!
Subframe fitted
309 arms fitted
GTi Anti Roll bar fitted
New balljoint bolts fitted
Just need to get new drop links and connect them up!
Can't find the lead to my camera so used my iPhone quickly!
It's all back down on 4 wheels now and turned round so we can pull it in the garage if needed!
Refitted my engine mount with nice new bolts lol!
Also got new bolts for the rocker covers and bolted them down!
Hopefully this time tomorrow i can update with and engine in shot!
Jackman
Finally!
Wolze came round to do the big drop tonight!
After a bolting a few bits back togeather and some faffing around we got it on the hoist and ready to rock.
With the help from a few friends, we managed to get it in with minimal scratches to the bay lol!
Still can't find my camera lead, so iPhone for now sorry!
Can't explain the joy i feel right now lol!
Only downer was that my freshly painted coilpack cover doesnt fit under the bonnet! So its been taken off for now until i can figure something out!
Massive thanks to Wolze for a super job again! And to Beefy and the gang for a helping hand !
grantley1988
Looks Perfect in there! I remember seeing you and the car at llandow, which must be a year and a half ago and then i had a soft spot for it. Now its a different league! You should be very proud mate. Fair play
dale205mills
Keep up the good work, I hope you are going down the root off hideing the wires for the clean look
Jackman
Alot gone on lately! Car is almost ready to rock!
The inside is all wired up and we trimmed my dash down to the bare minimum for now until i can decide what to do for definite!
Most the engine stuff is back on, all water pipes etc! Just need to mount the rad and then she can be fired up!
This weekend could be the time!
So...
Thanks to Wolze today, a big chunk was hit out of the car!
All the wiring is finished off, Water system plumbed in near enough, and rigged in a fuel system!
Sandy also kindly sent me a base map which is loaded up to my KMS now!
All seemed well and ready to fire up! But a broken injector and a problem with the fuel setup cut this short!
So until i can find another injector we are on a bit of a hold!
Apart from that the car should be off for mapping very soon!
Jackman
It lives!
BusEngineer
:) throttle bodies :wub:
:lol:
Sounds stunning fella
kubas
Nice sound !
What kind of driveshafts you want to fit ? Orginal from 205 or this from 309 with TU engines ? This from 309 are 1cm longer than this from 205.
Jackman
Thanks guys!
I'm running 1 shaft from a 106 GTi and one for a 205 Rallye!
If i have problems, i will source 309 shafts!
Nickmatthewsrallying
Its looking good, and sounds nice too...
Joe-Tait
Class project
dcc
Martin anychance of an update :) (and a passenger ride :lol: )
BC Devile
Love this project, Defantly a big inspiration for mine.
lemmingzappa
Just read the whole thread, lovely work <_<
Paulmac19
Well that passed a hour <_< love the project great work wish i had the skill and knowledge to do something half as good
Jackman
Thanks for all the kind comments guys, makes it all worth it!
Martin anychance of an update :D (and a passenger ride :D )
If i had updates Dan i'd happily give them! Not touched the car for quite some time now! Apart from moving it off axle stands and onto 4 wheels in the garage lol!
I'm hoping to get back on it soon!
Passenger ride will be sorted as soon as i can get to drive it!
Jackman
Little bit more done today !
Cleaned out the inside and hovered up all the s*it from 7 months of being sat!
Then chucked the drivers seat back in! And fitted the harness!
Also put most of the brake lines back on!
Most of the stuff is back on the bay now, so it will look alot like this for FCS! Will be a bit tidier once we know everything is back in!
I've ordered a new set of DS2500 today, so just need discs and the brakes can go back on and its back on the ground and almost ready for MOT!
Another effort from the big man tonight!
Fuel system tidied up - No pictures sorry!
Throttle Cable fitted !
Wosp Performance Slimline Fan purchased from Peter Lloyd on route home!
Just waiting on ties to mount it to the rad!
Throttle pot is also wired in, which pretty much completes the wiring!
So aiming to get it in for MOT next week now !
Sooooo...
Tonight the final wiring was complete! The fan is now fully wired in and working.
Wolze wired it to a override switch aswell just incase ;)
Also a spring has been attached to the throttle bodies to bring it back to fully shut as they kept sticking open ever so slightly!
And finally....It's a car again!
Jackman
Small updates.
Thanks to Durham and his mighty drill and bits, Wolze drilled out the blank prof green kindly handed me and mounted my gauges !
Wolze also took my vent to work and mounted my fan override switch which works a treat !
Then lastly Wolze created me a makeshift washer bottle after I lost patience with my last one and ended up ripping it out the car !
With a bit of luck it will be MOT'd tomorrow !
Bonjour.
Today I started to clean the guts off the Rallye as its insanely dirty even after washing it twice!
So me and Mr Green set about Clay baring the whole car, then i went round with some Meguairs paint cleaner!
Its not looking to bad now, still much work to do though!
I've also been on the phone to Colin this afternoon and the car goes down for work 2 weeks today/Monday 9th August!
Can't wait to get it back after that!
Jackman
Loaded the car up this morning and set off for Cornwall!
The car is now in the capable hands of Colin and Sandy!
hope to get it back sometime next week :D
Batfink
whats colin doing to it :D
Jackman
Just some exhaust work mate!
Although i really fancy his Satchshift lol!
rallyejames
hey up mate just wondering if there is any chance you could tell me the paint code for your rallye? i have the same and currently doing a full restoration on it. i need to know the code so i can buy the paint to do the full car. i have looked high and low for it but just cant seem to find it anywhere. cheers james
