Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Spiky
once i get them, i take some pics and show :lol:
Spiky
Made a start on the fuel lines today
here are some pics from tonights progress :rolleyes::rolleyes::rolleyes::rolleyes:
Edited by Spiky
projectpug
Looking good did you repaint the shell? Looks very clean inside too looking to respray the floor in mine eventually
Spiky
no, haven't painted anything,
thought i think i will at some point as it has a few scratch's where i have be walking around on the inside now :)
Garry
Looks good Spiky, this is what I intend to do over christmas.
Can you confirm the details of the Swirl pot kit please?
Spiky
i got my pot from
http://www.sm-engineering.co.uk/alloy_fuel_surge_tank.php
the rest of the fitings i got from summitracing in the US
i run two fiters, one either side of the external pump
i needed more fittings so cant really do much no,
so today/tonight i will start ripping the brake lines up as i plan to run these in the car now :)
Garry
Can you explain how the system runs?
I assume you connect the 'in tank' pump to the swirl pot, so that it fills it with fuel. The external pump is then gravity fed from the swirl pot and pumps the fuel to the engine.
Where does the fuel return pipe go to?
Also, does the 'in tank' pump keep running and circulating the fuel to the pot and then it returns to the tank? Is there a risk of the 'in tank' pump not being able to keep up and the pot being emptied?
Spiky
the way i'm setting ming is as follow
the in tank feeds the second from bottom connector to fill the swirl pot
the return to tank connects to the top fitting on the swirl pot
then from the bottom fitting goes to the first filter, then to pump then to filter, then to enging
the return from the engine goes to the second from top fitting to fill the tank
i will eventually probably change the intank to a facet low pressue pump (if i get issues)
you are right the intank will keep circulating from petrol tank to swirl pot
felix2566
Been following this for a while its looking real good!
I was looking on the summit web site, very good prices on stuff, but, how much did you pay for postage to the UK? Was there a minimum order value? How much did you have to pay for customs duty?
Alastairh
Great progress!
Spiky
cheers guys:)
the first order i did was 550$ and had to pay 60 quid on top to get it off parcel force :excl:
my second order was only 180$ so i'm hoping for it to be a lot less
Jon_Bmw
Import tax is a pain in the behind, its a shame they have wised up to the whole gift thing. :rolleyes:
stuart
How do you plan on sealing up the fuel pump / sender access holes and where the fuel lines come through into the cockpit? Also, how do you make up the ends of the fuel lines with the PTFE lined pipe?
I'm building a 205 rally car at the mo (see thread in technical section) and will be doing something like this myself fairly soon.
Stu
Spiky
to seal the dodgy looking hole, i will put some rubber around the pipes then seal with polyutherne sealer
it's not ptfe lined, its high spec high pressure rubber reinforced
EAR-420006ERL thats the part number on www.summitracing.com for the pipe
smighall
If it isn't PTFE lined aren't you going to get a strong fuel smell in the cabin?
Spiky
i'm told, that with this pipe i shouldn't
soon find out i guess
smighall
Be very interested to know what you find, as that's pretty much exactly what i plan to do.
Spiky
once i get my next lot of bits delivered and fuel rail back (as it's off getting the dash fittings braised on) i will se if it smells
just need to finish the wiring off for the pumps too, just awaiting my inline fuses to be delivered
Spiky
well here's tonights progress
finished off the wiring for the fuel pumps :top:
all the fuel pump fittings are now here and fitted, just need some mounts for the pumps and filters now and the done, and just need joints tighened up :DD:
new rear discs and DS3000 pads :DD:
better than what it did look like
Powers
Looking sweet. Keep up the good work.
Spiky
see my other post about the rear brakes :rolleyes:
Powers
I have now, dumb ass! Pmsl!
Take the sliders out, clean them, and re grease. I have a mintex product designed for these if you can wait until Monday. Don't use copper grease as its to abrasive.
projectpug
Looking sweet B)
Spiky
well decided to make some more profress today :DD:
here's the fittings for and new pipe for the fuel system
decided to get some more through for the oil cooler
old fan cowling "slightly" modified :DD:
oil cooler location
Spiky
plenty of room between the oil cooler and rad
new spal fan
and fitted
