Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Leon
omp cage is easy peasy to fit :(
Yep, exactly what I found.
That said, I had to take one out the other day on my own which was a bit of a struggle as the sleeves that hold front to rear had welded themselves in place but it relented in the end! :)
Spiky
well this is what the car look like now B)B)B)B)
this is just before we put it on the trailor and sent it to have the cage and seats welded in :banana:
Spiky
well been to see the car tonight :):D:D:(:blush:
this first pic was made by andy (the guy fitting the cage) which is identical to what comes with the cage, how fooking cool :blush::blush::blush:
this is needed due to me wanting an extra diagonal on the rear :D :DD: :DD:
and as you can see the sun roof is gone, and a sheet on thin metal will be bolted on to replace it :D:D:D:D
Spiky
smckeown
It's exciting to get a car back after being prepared eh! Never seen that rear belt bar done like that before..
Spiky
well dont look the same now :):P
cage is all out :D
seats out :o
brakes have now been bled B) (cheers Paul B) )
hamerite the base welds tomorrow and paint the cage in the week B)
time for a test drive tomorrow B)B)B)B)
_________________
dommorton
Looking good :rolleyes:
Really liking the harness bar idea
Spiky
been painting the mounts and cage today, only hammerite paint, as it's not concourse...:lol
Discostu
Looking good B):P:D
The harness bar wasn't what i was expecting but still, i think it looks quite good.
Will pop up again soon
boombang
I can't help but be bothered by a couple of things in the setup.
The rear of the seat bars looks welded onto the handbrake housing - but that itself is only spot welded onto the shell and they have a habit of coming away from the floorpan and in a lot of cases they crack too.
Look like a couple of small welds on the bars to floorpan but have seen the floor crack there too.
Could you get a couple of gussets up from the floorpan itself and weld up the join of the handbrake housing to the floor?
Other worry is that harness bar location. I know how flimsy the areas the plate is welded to is. On first look I wondered if it was going to be up to it, but there is a fair bit of weld there so I guess it could be ok.
Might just be a total over-reaction though and I am no expert.
Edited by boombang
taylorspug
I was about to post pretty much the same thing as Boombang. Ive done a fair few cages now, and i really dont like the look of the belt bar, one big impact and that is going to shear straight off.
Personally i would have either found some way to mount the belt bar on the cage (doesnt look too feasable due to the size/position of the cage), or put a large strengthening place into the rear inner arches and mounted the bar between them.
jonnie205
Ok, chop that seat belt bar out and chuck it away, to be honest it would be far stronger to just use harness eyes in the floor and would look much neater too.
The seat rails look ok but i would massively reinforce the inner mounting on the rear one and if it were me i would have mounted passanger seat lower and further back. The rear seat rail takes 80% of the seat load so its worth making sure its right.
The welding looks very good and you have dont a nice job of the cage mounts etc.
Spiky
appreciate the comments, and i'll pass them on to my fabricator,
but the rear bar is solid as a rock, so wont be changing that,
but sort of agree on the seat mount, which is an easy fix :P
any how
here is the last of the pictures for this weekend :P
pdd144c
Looking good, but that harness bar is dangerous!
Spiky
well here's a little update from today ;):P
the roof is drying so will take pics of that when it's done,
it'll be white hammerite on the underneat and black hammerite on the top :D:D
dropped my battery cables off, and andy has done such a great job of the crimping :D
Spiky
also me and Powers went for a little drive in it,
and here are some pics we took
Spiky
and my latest mod :content: :content: :banana: :banana:
309 rear beam
johnnyboy666
hope to see that beam put to good use soon!
Spiky
well a small update :top:
i've bought a 309gti B);):lol:
so will use it's rear beam, front wishbones and drive shafts, so should make it handle even better B):wacko:
also have a few spare bits like, loom, engine,gearbox :D:D:D
not bad eh B)B)B)B)
here's an update on the sunroof :cool:
Spiky
latest mod turned up this week :blink::blush:;):P
Gel battery :P
Guest harry snotter
looking great m8, that rear bar should be well up to the job :excl: , better than a 2" plate on the back floor at the wrong angel :) keep up the good work its great to see how other people go about a build :blink:
Spiky
little update from today ;)B);):(
Discostu
Looking really good fella :D
Spiky
well my front tyres for dry days have turned up B)B)B)B)B)
Big u SIB for sending them, even before receiving payment :P:(B)
and at an amazing price too :oB):D:D
Edited by Spiky
smckeown
getting serious then : )
I wonder how they compare to Yokohama advan's in terms of the optimum negative camber needed.
I assume you can use these in the wet also, just not standing water wet. I have my yoko's fitted all year round.
Are you planning to renew/replace any of the front suspension. From the look of the pics the top mounts are rather old.
