Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Spiky
here's another spare 1.9 engine
Both 1.9 engines are forsale
above also has one of 3 gearbox's i have ...lol
abd here's the box i'm going to use, a 1.6 box
also bought a n ew radiator for the car
some other bits to go with the GTI-6 engine
and my 309 beam ready to go on, once the solid rear beam mounts come
Spiky
bit more of a update from tonight :top:
gave the engine bay a bit of a clean :)
all by hand too :eek: :P:blush:
and here is the subframe and rack, which i'll blast with the water pressure jet tomorrow :blush::)
pj838
Looking good there mate, I am doing the exact same thing as you, got my engine out yesterday ;) love it when the shiny new stuff arrives in the post too! Now I am tempted to drop my subframe off, seeing as I have new everything to go on, tried to get the ARB out with the engine gone but it was a pain in the ass.
Did you find much rust in the engine bay?
Spiky
no none at all really ;)
edthedrummer
looks awesome. really inspiring. if only they let 16yr olds with no license out on the track.
They do! ;) Well, in some event's. A 14yo lad i know was out on an autocross a few weeks ago in a 1400 205, came something like 8th overall, beating many more experienced drivers and expensive machinery!! His Dad does own and run a Rally School though so he's kind of had the practise!! ;)
Spiky
well here's what i've been doing this week :D:DB)
big thanks to alex and sarah (for helping and putting up with me living in the garage..... lol :) )
it's a tight fit :D:)
easy once you get started isnt it! looks like you're doing good progress :D
Spiky
yeah it's going ok, all coolant pipes made just nedd jubilee clips and one metal pipe modified for the oil cooler
as for electrics 90% done, will finish once engine is started as i dont know which wire is for temp gauge and which for temp warning
need to get exhaust modified,
new lambda and crank sensor
and new longer thottle cable
not much else
one thing i dont know is where the brake reservior comes off, but i'm sure i'll work it out soon :D
welshput, also thanks for your help
will let you know how the diodes and rev counter get on
this one should help identify any wires you may not know yet.
http://forum.205gtidrivers.com/index.php?s...round+multiplug
as for a TDC sensor its 1920 W9.
throttle cable you can get as a kit from GSF.
brake resevoir on teh 205 just pulls off.
my rev counter works :) (but my bloody injection double relay has just failed :D )
Edited by welshpug
Spiky
no, no, i know all the wires, they all labeled up :)
just dont know which way around the temp gauges are :)
the rest are fine :D
ohh the gauges, yellow is the light, brown the gauge.
check my edit above
Spiky
cheers for the extra info, sorry i had a typo above i meant the breather off the brake reservior, sorry
ohh, same again :D (its a vacuum pipe actually)
Mikey G
no, no, i know all the wires, they all labeled up :D
just dont know which way around the temp gauges are :D
Turn the power on on the car and get a volt meter on the wires, ~6volts for the gauge and 12volts for the stop light :)
Looking good spikster anyway, may get to see it short(L)y :)
Spiky
well it's been a VERY busy few days and i almost finished :top: :top:
the engine is now running, although lacking water, due to one pipe needed modified for the oil cooler :top:
here is a quick vid of it starting and purring :banana: :banana: :banana:
i'm as happy as a pig in s*it :cry: :cry: :cool: :cool: :cool:
Matt Holley
Nice one you have made some quick progress with that ^_^
Are you going to the euro day at combe in september?
Spiky
Nice one you have made some quick progress with that ;)
what date dude? any more info?
i'm booked on at croft 1st and s2nd of september, it's first outing in new spec ^_^
Spiky
my name is now down,
cheers fir the pm matt :huh:
and mikey G :)
pj838
Looking very good :). Looks like you used the gti6 engine mounts after all then? How did you set up the alternator - I am looking at making my own bracket up...
And what about the clearance of the exhaust manifold, any big problems?
Wish I worked as fast as you :)
Spiky
yeah, fits fine with std mount
alternator is a modifed 1.98v one, i'll get pics if you need them
with a mi16 alt bracket, again i'll get pics
only mod was to extend the bottom moutn 7mm
clearance on the exhaust is perfect, dont touch anywhere, and lambda is face upwards, which show how much clearance i have
Spiky
here the pics i mentioned
Spiky
and here is the car ready for it's mot tomorrow
new foam on the roll cage :)
and new bonnet pins, due to me moving the rad forward a bit, the bonnet catch, was sticking a bit
and for safety
Stonesie
looking good dude but there is 1 thing i would have done.... i would have replaced the cambelt and tensioners as you will be giveing it death on various track days...... Unless you know the history of that belt and tensioner/idler set as its clearly not brand new.
