Matt180
[project] 205 Gti 180 Track Car
Matt180
Photobucket is where i store all my photo's. Ill try again!
6E25DF2A-3BA4-4702-9C86-0DC76C5A179C_zps
BBEF499D-8109-4573-B198-52968801B316_zps
F724408E-49B3-449F-83F3-9F4F337BDF95_zps
Edited by Matt180
barneys66
Wow - some seriously impressive work going on there!
Watching with interest..
rallyeash
Awsome
Matt180
Here's a few other bits that i have been working on
Custom reduced size (130mm) 8 rib alloy pulley. This will allow me to reduce the size of the S/C pulley without overspeeding the charger and save a lot of weight!!
F1DAD5E9-8867-4CFB-9142-B24D0EF6C0E2_zps
Also had brackets and bells machined up for a pair of light weight AP 3696 calipers
4C87989A-73EF-4970-A10E-A893B5270A97_zps
BB37A470-19D8-4430-82F0-536C3A21314D_zps
Matt180
You may have noticed the extra holes in disk bells. I decided to re-drill 4x100 due to lack of wheel choice in 4x108. I have gone for 949racing 6ul's which are about the lightest on the market....the 15x9's weigh in at 5.8kg
CF52F7B1-B5B3-4457-885C-D0FE6C3F60F3_zps
CC8358DF-2947-42B6-949B-A9678C47B7D7_zps
mechanicalrepairs
Amazing build, you have some great skills.
Carl
What offset are your wheels?
Matt180
+36
How do they not hit the strut?
Matt180
Because i am making my own hubs and struts
Edited by Matt180
chrisj21
Super impressive work there Matt, liking that subframe a lot!
davenport
Some fantastic fabrication and thought here... 10/10 on this fella
zeebraa
Looks awesome.
Matt180
Thanks for all the comments guys!!
Fabrication on the fromt suspension has stopped for a short time while i finalise some designes and wait for machined parts.
I decided to get the engine mounted so i can start mocking up rad/intercooler postitions etc.
39D82B2E-16C0-4302-A404-06EF39CD1749_zps
I did a little experiment with a stanard 180 inlet manifold measuring air flow from each port at a set pressure. The differences between them were fairly substantial!!. Decision made, centre feed inlet......
66D0B718-39AF-4215-8748-5E25165D23F0_zps
The inlet plenum just needs trumpets welding in to finish it off
723D9711-46DB-4B79-8852-E82B31ED3C11_zps
Also made a expantion tank/oil breather tank combo to make best use of the space i have.
3A6C5E5D-E485-4995-A143-F5A6CA9ACEEA_zps
6AFE1348-DCA1-414A-BA39-65D3D5FB7144_zps
Quaife quickrack getting built
DAEC45DA-222A-4B94-8BE5-A1244B34D75F_zps
Kane
Top work! Whats the purpose of the modification to the inner wings? Clearance?
Matt180
9.5" wide wheel/tyre and low ground clearance
Kane
Whats the plan for wings/arches as being that low and wide I'd imagine you'll be chewing up tyres with standard sizes
Matt180
Im not sure yet. I didn't want to go the dimma route but it will be something along those lines. I might try contanting some fibreglass companies to see what they can offer
zeebraa
What are you using in the mounts for bushing?
allanallen
I like this a lot
That is all
Matt180
Engine is solid mounted, no need for bushes
Gman
How come you're not using your old rotrex setup. That engine was fantastic
Matt180
I am still using the rotrex, with a forged sandy brown engine
Reebmit
  On 1/28/2016 at 8:19 PM, allanallen said:
I like this a lot
That is all
So do I.... Allan, nothing like good engineering :) Edited by Reebmit
