Dj_mini
[race_prep] My 205 Mi16 Track / Hill Car
Sandy
Ace!
edbar
Absolutely love it, great work by all involved!
westy
Looking great!
I'm only down the road so give me a shout if you need a second pair of hands :lol:
Dj_mini
Small update iv made the loom to suit my new s40 ecu :
So iv now sent it off to sandy all being well the engine will be on the dyno before the end of the month. in the mean time ive been putting the shell together ill take a coulpe of pics when im out there next.
Cheers Dan
love how small looms are for aftermarket management systems!
Dj_mini
lol doesnt take much for them to run.
Iv made a bit of progress on the shell but forgot to take any pics :)
Had another small delivery today:
:) following on the theme of the shell eh!
how much does that weigh?
Sandy
About the same as the packaging I expect!
Dj_mini
Not sure my bathroom scales wont read low enough to find out :P Ill borrow james fishing scales tomorow so i can find out :)
projectpug
Why not weigh yourself and then pick up the flywheel and take them away to find the weight of the flywheel.?
Looks good though how much did that cost and who did it if you don't mind me asking?
Spiky
thats how i do it...lol
i wouldnt mind know the cost too please
there are billet ones for the gti6 weight 3.6kg for 200
Sandy
A few engine bits:
Lightweight slipper piston (30% lighter than an Mi16 Omega!):
Custom made con-rod to suit:
Custom JRE profile cam, double springs and solid lifter:
Lightened, precision bored/honed and surface ground block:
The spec as it stands:
Iron block 87mm bore x 92mm stroke (2188cc)
Forged steel crank
Robson custom spec con rods
CP custom spec lightweight slipper pistons
Wet sump lubrication
XU7J4 head ported by SB and Mark Shillaber
JRE custom cam profiles
Cat cam adjustable cam pulleys
Piper double springs/retainers
Solid lifters
SB custom inlet design made by Colin Satchell
Jenvey TH bodies and DJ custom panel filtered air box
Custom 4-2-1 exhaust manifold to JRE spec
Custom two box exhaust system
grandos
Looking awesome, and I must say those pictures of the pistons and conrods, Engine Porn!
cybernck
this is really a mind-boggling build :).
what i haven't figured out is what are you doing / have done with the white car?
interesting to see flywheel with timing teeth on!
btw, how would it fare in turbo application with all those holes in... looks a bit, errm, dangerous? :P
thanks.
this is really a mind-bogglind build :).
thanks.
all the holes are outside where the friction surface is and pressure plate bolt on, there would only be strain on that area when starting?
Dj_mini
Looks good sandy first time iv seen all these bits iv been paying for :)
this is really a mind-bogglind build .
Its been a long time coming the parts didnt exactly arive when me / sandy had hoped but its nearly all there now :P
The white car iv broken all the bits i wont be using again have been sold (i have a few bits left to sell keep an eye out in the forsale section)
Iv started swapping all the small bits over to the new shell i must take some pics when im there next.
The flywheel is for a race 7 1/4 clutch so can be lightend more than a std type sandy sugested this route as it make the whole rotating mass less as the fly wheel can be lighter and the clutch itself is lighter.
Cheers Dan
Batfink
any reason you kept a 7 1/2 clutch? 5 1/2 is even lighter and smaller :P
Dj_mini
any reason you kept a 7 1/2 clutch? 5 1/2 is even lighter and smaller :)
oooh 5 1/2 even less weight sounds good :P Only went with the 7 1/4 as the the flywheels are off the shelf and helix seam to think there clutch will do the job and be suitable for what im going to use it for so went with them. Not sure what pedal feel you would get with a 5 1/2 prob have to go to a hydraulic release bearing?
edbar
Positively filthy! Gives me inspiration for when i go 16v, looks like its going to be an incredible build!
Batfink
oooh 5 1/2 even less weight sounds good B) Only went with the 7 1/4 as the the flywheels are off the shelf and helix seam to think there clutch will do the job and be suitable for what im going to use it for so went with them. Not sure what pedal feel you would get with a 5 1/2 prob have to go to a hydraulic release bearing?
Not sure but I reckon your flywheel wont be much heavier as it looks pretty thin! The difference is the clutch itself. I only did it because my gearbox housing is smaller. Its at Colins so have a look!
I think if you haven't already, have a look at what clutch housings you can get. Aftermarket twin plate ones are really light in weight compared to standard type uprated ones, and I think the greatest weight saving is here.
How is the shell coming on? can't wait to see this finished and get a final weight as its an inspiration to me for shell dieting :lol:
Was looking at your front inner arches...why dont you cut the whole metal part out and run a bit of kevlar sheet or plastic or something?
Dj_mini
How is the shell coming on? can't wait to see this finished and get a final weight as its an inspiration to me for shell dieting :ph34r:
Colin showed me your casting (before it was repaired not sure if he managed that in the end?) it does look small bit late now for me as the the helix 7 1/4 has turned up today :lol: pics to follow just need to measure up for a release bearing now to see what i can do with that.
Iv tried to think of all the little things but even now theres things i would do diffrently with the shell as its been over a year in the making so iv thought of ways to improve it but thats going to have to wait a few years before i get the chance to reshell again <_<
I kept the inner wing and drilled it as i had a problem with my fibreglass wings flapping abit last time so they need a bit of support but as you have said an ally strut plate would prob do the trick.
Sandy
7.25" is ideal, smaller isn't really going to bring you any benefit and will likely be less friendly to use.
Stop fussing! I was thinking about the overall car last night and it'll frankly be the near perfect track spec 205, you can always make things better, you should always try to make things better I think, but it's nice to finish stuff sometimes!
Dj_mini
I will remember that quote sandy ;):D
Sandy
A rare pleasure for me I know!
