Jonmurgie
[track_prep] Mi16 Track Car - Going Back Together!
hexhamstu
whats the pros of an airbox to filter instead of just a large filter.
smckeown
noise reduction mainly.
Jonmurgie
Yeah, that's what most people say though it's still noisy as hell! I acutlaly run with a direct cold air feed to the airbox when on track, as shown in this picture:
I'm going to look at the space there is above the radiator agian and see if I CAN get the oil cooler there...
smckeown
Is there any other reason then ? less turbulance ??
Jonmurgie
Yes, I think that is part of it as the trumpets are seeing steady calm air and don't get 'buffeted'. I suspect it may also alter the power/torque characteristics a little, though I doubt any of the peak figures.
It was something I wanted to do a back-to-back on the dyno with but I've now sold the Jenvey airfilter so that won't happen now...
Jonmurgie
A little update... managed to sort out a -12 JIC fitment oil cooler, everywhere seemed to be out of stock!
Also got my plate CNC'd for fitting the oil filter to the side of the head, well pleased with how it's worked out:
More updates tomorrow :blink:
Martin@PRD
Looking very nice and tidy Jon :blink:
smckeown
that's a big oil cooler - 18 row ?
Jonmurgie
Good-o, the bracket fits (pics later) :(
Cooler is a 19 row, simply because there was nothing smaller in stock anywhere (resonably priced) and that included Think/Mocal! I cam either cover some of it up or change it for a smaller one if it over-cools but we shall see how it goes :blink:
Jonmurgie
Some pics... first we have the modified head water housing, and second is a modified rear block water housing. This now means no heater matrix plumbing and no pipe running around the back of the head.
And I quickly slung the fabricated bracket onto the head to see how it all fitted, and it's perfect :blink:
Next is to fabricate some oil cooler mounts, then finish up the pipe run and get those pipes!
tidypug
that looks fappin great. Good job!
Alastairh
Very nice
paul205mi16
fairdoos! the litle things make the biggest differences-looks great.
Rik
Got any dimensions for that if you dont mind?
Could do with sumet like that for my coil pack!
Edp
Looks great all this shiney stuff. I bet you cant wait for all the dirt and oil to cover the engine once its been ragged round a track :D
veloce200
you're a purveyor of automotive pornography Jon! :D
Edited by veloce200
Mattsav
If you add an vertical bar from thin ally strip (6mm wide x 3mm thick ish) that runs vertically down the side of the oil filter (joined onto you new filter housing bracket) then you can place a large jubilee clip round the strip & filter to make sure the filer can't vibrate loose (if that makes any sense.....)
Doesn't look quite as bling but can save the engine!
Jonmurgie
Few more updates... radiator and oil cooler now fitted, got to add some cowling between the oil cooler and rad though to prevent 'dead air'
Also started putting the interior back in
Some major progress will be made this week and at the weekend I'm trailering the car down to Merlin Motorsport to have all the pipework made up for the dry sump, brake lines and fuel lines :ph34r:
Updates and more pics here: http://www.mdracing.co.uk/rebuild.asp
Butler
Gonna paint the interior?
Jonmurgie
Yeah, gonna give that a new lick of paint before the seats etc. go in... probably this weekend, once the pipe runs are all worked out :D
smckeown
bright pink would certainly brighten it up a little in the cabin :D
Jonmurgie
BLACK I like everything black... everything IS black... it's all black... black... :D
anyone want to buy my car?
smckeown
love the subliminal messaging :D
huckleberry
" I see a red door and I want to paint it ....."
Guest
