acox99
Tesseractoid
Sorted my loose feeling gearstick, fitted new gear change rods, the TU L linkage pivot bush kit and a couple of bronze shifter bushes, worked a treat, nice and snappy now!  quick video attached.
Edited by Tesseractoid
Leslie green
Taken my 1.9 gti driveshafts apart , there are 99 needle roller bearings on each one and once you take the joint apart there is nothing holding them in anymore and after a lot of searching I found them all , on the floor , in the bin ,on the bench ,in the cv boot lol
  • Haha 1
AlexRS2782
Today i mainly swore at the car as, a month before the MOT is due, it's decided to seize the passenger side door in the permanently locked position.  Motor still working as the button goes up a few mm then re-engages down to locked, can't lift the button inside the car to unlock it, and the key wont turn more than a few degrees in either direction if you try to free it manually via the key (resulting in the metal around the lock starting to flex).  The list of niggles is beginning to grow again (hasn't been that way for a while). Bloody car lol.
Only bonus being the insurance renewal coming through at only £10 more than last year, and that's with an increase in value of the car from the previous policy.
Edited by AlexRS2782
SweetBadger
Fitted a linear actuator to my accusump valve… because why not!
Also a damn site cheaper than the cable operated remote valve kit from canton.
You'll never free it by forcing the key,  it'll be the pivot on the inside of the outer handle seizing up.
karabas
After disappointed with the cracked cylinder head, I found a one.
We will be on the road again soon.
I applied the degree method. I used the torque wrench to see the values.
60Nm first
slacken
20Nm then
The plan was 90+90+90 degree.
at the second 90 degree torque values beyond 110 Nm which is wrench capacity.
It was really hard to complete second 90.
I tried another 30 degree instead of last 90.
I tried extremely hard put all my power for the last 30. Only the number 9 bolt refused to turn last 30.
Get a bigger (longer) bar.
AlexRS2782
Took it past 125k on Friday - the reward for that was the interior fan blower starting to play up and turn itself on / off whenever it likes before eventually settling on.  I'm guessing a combo of the fan itself and maybe the resistor too as the fan speed it settles on is the same regardless of where the control knob is positioned.  Already have a decent working fan in spares and bought a new resistor from a seller in France which turned up in 2 days - quicker than it takes some of the UK based retailers to post / deliver.
Starter click is also back so i think i'm probably going to finally bite the bullet and get the engine bay loom checked over / refurbed as no doubt there's probably some minor wiring damage hidden somewhere between the ignition and starter.  Plus the car's been running fine since i put the brand new tachy fuel relay in last year.  Add that to the list of getting the car undersealed properly at some point this yearand also treat / paint the passenger wing area under the bonnet as that's starting to get some surface rust setting in which isn't ideal as it's on the earth point around my Morette's.
AlexRS2782
Nice weather gave me the opportunity to have a clean around in the engine bay and remove quite a few years worth of grime from under the bonnet, etc.  Came up pretty good considering but probably needs another going over to get it nicer.
Ordered a new starter motor as part of the plans to overhaul the remaining bits on the starting / ignition side of things.  Hopefully that will turn up by the end of the week.
Telf
i took mine out for the first time in ages. Its been sat looking sorry for itself on the drive for months.
Drove to the coast in the sun and had a few waves as people overtook. A guy in a McLaren decided he needed to show me his car was quicker than my 205. Made me smile.
  • Haha 1
Spot of road rallying on Saturday night, a good but challenging event, the navigation looked to keep the left hand seat very busy, Gary was only just keeping ahead of me at times. Happy with 6th overall, only 3 seconds off 5th place. Photo thanks to Jez Turner.
chris 417 mi
:)Started and moved her for the first time since winter, bit of a photo opportunity with her garage mate in the sun then back away till the end of the month
Leslie green
Took the laser out for its very first run across the field to a car park to bed the brakes in and it promptly broke down within 10 mins here and had to be towed back in again , not a great start lol
SweetBadger
Took mine out on its 1st track outing last week after some improvements over the winter - bridgecraft roll centre correction kit, hydraulic clutch conversion.
arrived at Snetterton misfiring due to suspected fuel starvation… :angry:
After pissing about under the car all morning changing fuel pumps, it still wasn’t right, finally discovered a blocked fuel filter! With that removed, ran the rest of the day without a hitch!
Front end even more pointy with the roll centre kit now that the wishbones aren’t pointing upward. Highly recommended upgrade if your car is significantly lowered.
ScoobyJawa
Taxed it. Bloody hell, how much these days :o
Leslie green
Tax ? £198 for 6 months now not a bargain for a 34 year old car ! Took mine to a show on sunday it ran lumpy most of the way there and back (110 miles ) and was generally a pain to drive  needs more work I guess !
Edited by Leslie green
chris 417 mi
Replaced the all fuel lines on the little 1.1 as after the winter lay up they decided to split !
Full new lines, hoses and filter for good measure right the way though with the bakers units off a gti.
Then the sump needed swapping as it had became slightly rotten!
Brakes all round next along with swapping onto the rebuilt gti beam I’ve obtained locally :)
Edited by chris 417 mi
NOsMAN
Taken it to MOT station and it passed :P. Mucked around with the K&N and pipework and its been running very well which surprised me as its been misbehaving for a while, no hesitation like before and it revved easily.
Leslie green
Did 110 mile in the laser yesterday as it was sunny out   , ran fine idled at 1000 rpm , when to fill with e5 sul and picked wrong pump up and had 10 litres in before I reaised , so topped up with E5 . Getting 28 mpg   few small jobs to do but would rather drive it
quite unlikely you'll notice any difference unless you had cranked on more ignition timing on the Super unleaded,
Leslie green
I was hoping too add a little more Mei without having to worry about pinking as much as it goes much better when you add more timing ,the difference really is very noticeable right through the rev range not just high up and makes it what id expect as its a bit flat otherwise ,disappointing even ,I think a few horses have gone missing lol  down side is the idle goes up quite a bit but I want to add some while keeping the idle at a sensible level and try and find a sweet spot through trial and error  , at the minute I can get it to idle below 1000 rpm so I think there is room for a little more timing.Plus less ethanol can only be a good thing in old cars .
Gohn
finally, finally fixed a super annoying oil leak
assumed for months it was the sump gasket
until I tracked it to the oil filter/heat exchanger (only on the turbo diesel) which bolts to the block just above the sump join
the 3 bracket bolts and the centre bolt ALL needed tightening, and there are two o-ring seals plus the oil filter seal itself
hard to tell exactly which one was leaking
new o-rings, tightened up the bolts and no more leak !
ScoobyJawa
Had a new timing belt and water pump fitted. More pricey than I thought it would be since I supplied the parts, but glad it’s done.
also mot’d at same time, no advisories for the 2nd year running :)
had some weird hiccups the other day, driving around and the stereo kept turning off and back on again. Then mid way through journey stopped doing it and been fine since. I do think there’s a gremlin with the fitted alarm/immobiliser I’ve had some previous weird issues particularly if I don’t let the alarm set and settle. Might get it removed at some point….
I've done a lot of 205 8v timing belts, assuming nothing goes amiss its 3 to 4 hours work start to finish to do the belt and water pump, bleed the coolant and run up, etc. But, that is to me that is very familiar, to someone who has never done one and is feeling their way through the job, it would easily take them longer, some of the belt cover fixings are difficult to see, you have to feel for them, and the spring loaded tensioner is a simple and clever system once you are familiar with it, but to someone who has never done one before, could understandably take some head scratching to figure out what the hell is going on.
I’m busy with this at the moment. I should probably write a thread about it, I miss build threads these days.
No engine or gearbox in at the moment, but having fitted the tyres to the wheels I wanted to see what they looked like on the car.
  • Like 4
