wracing
[project] Peugeot 205 Twin Turbo
dcc
whats the flow rate on an m45 charger? would it act as a bottle neck at higher speeds? on track you wouldnt let the revs drop below 3500 anyway? also, a twin charged mi16 engine should be around/over 300bhp / 250ftlbs torque, pretty sure you are pushing the boundaries on shafts and gearboxes here.
wracing
Well, Im just been greedy, you will never have your turbo spooling at idle unless it is tiny or you are using antilag. you get to clear dollops of power one at around 3500, you can hear to turbo spooling at 3000 and one at 5200 and you can hear the large turbo spooling at 5000,
The power falls off at 5800 because I haven't got the staging right between the 2 turbos. it then comes back once the turbo is fully spooled. and produces loads of boost right until I get scared!! So the twin turbo is defiantly working and it can only get better with mapping. i've got to spend 2 days on the dyno @ 600 pounds so im trying to get everything done before!
Im not really sure where I should set my redline as its fully forged, bar the crank.
The only reason you would want a supercharger on this engine is so you have that power off the line and if i ever shift below 3500, im thinking highway fuel efficiency :lol:
wracing
If I ever put the eaton on this engine, I would run it so it would be decluched and fully bypassed when above 3500ish.
Its just a idea i haven't sat down and worked it out, and for 15kg more weight it would add loads more drivability! :lol:
James
BERTMAN
Its just a idea i haven't sat down and worked it out, and for 15kg more weight it would add loads more drivability! ;)
James
i think thats how they did it with the Nissan March SuperTurbo.
by the way, your mad... keep it up :)
[L'e$kro]
Impressive build James
Topic flagged, now waiting patiently for videos...
And meanwhile I'll read the megamanual about CAN communication, I like the idea of your integrated nav system speaking the MS
Nico
shalmaneser
I'm confused and worried by the lack of videos here!!!
Awesome project!
wracing
All in good time :lol:
James
qwerty
VIDEO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:D
No pressure James :ph34r:
Daviewonder
Any news on the Eaton fitting? :ph34r:
madspikes
only just found this thread! Totally Awesome!
Motivated me into getting e45 pug back on the road!
mad
Joe-Tait
Crazy build
guffe
What's up with this build? Any progress?
wracing
Ok time for a quick update.
As always with large scale projects they are a bit of a drain on finances, after a little break we are back working on her.
I've had a few issues with my throttle bodies, swallowed a butterfly!! luckily no damage, I had to replace the throttle spindle and now mounted the throttle bodies properly.
I've have moved the header tank/swirl pot to the front of the head, we where getting localised boiling and air collecting in the head. We are hoping that this swirl pot will correct issues.
We still have to finish the loom.
James
Paulmac19
Coming along nicely glad to see your back at it, looks sweet :)
wracing
Loads more work done, haven't got many pictures at the moment.
A nice video of the practical first start, fixed loads of problems, running sweet.
Cam belt running a little tight :)
James
Ben_M
interesting build! when do you think you'll be finished?
wracing
Within a week hopefully :huh:
Pugcrazy33
you crazy bastardddd!
jonathan205
wowza! how you gonna get traction?
AJA_GTi
Fantastic mate!
You can buy the parts and resources and even the time but your knowlege and balls are priceless!
Any updates?? :lol:
wracing
After a really s*itty track day in September we have been hard at work with a custom dry sump set-up with 3 scavenge stages (1.25"). My bedroom is currently covered in electrical cable as now everything is in its final place a proper loom is getting made. Also in the process of upgrading to megasquirt 3.
The final addition to the car is a pressure system controlling all the dump valves and waste gates with out having to rely on manifold pressure. We have been having a problem where the boost hoses where getting blown off on throttle close as the dump valve wasn't opening due to low vacuum.
The list is endless but I'm getting there B)
AJA_GTi
Rome wasnt built in a day - keep at it young fella! ;)
Tim 892
This is just imense very rear I sit and read a complete thread but I have just read the lot in one go! 10 out of 10 for this one!!
rallyjonesy205
this is immense. just read whole thread you are truely mad. one of my mates went to the track day and said he was chatting with you. real shame you couldnt get it going. i did pop over but you had already gone.
Edited by rallyjonesy205
