wracing
[project] Peugeot 205 Twin Turbo
omega
wraceing
i dont care if your moter makes 200 or 2000000 bhp.i enjoy reading your thread [even through a lot off it is well over my head]
i admire they way you keep getting on with it and improving and getting round proplems and your craftmanship.
you are doing things that most of us havnt got the skills,resources or cash to do and can only dream about and iam sure that other people will pick up ideas,tips and insperation from this.
so keep at it
from
a very intrested keyboard warrior.
wracing
Started off originally at 8.7:1 but now around 9.3:1 compression ratio to improve off boost response, mainly achieved with decking. ideally I would have preferred to have custom pistons but these were not feasible when we originally built the engines. I had plans to high 10:1 but we couldn't make this work with the fuels we wanted to run.
IMO megasquirt is one of the best offerings on the market. Cameron is right megasquirts rep has been ruined by cheapsakes. I use megasquirt because its opensource souftware & hardware that allows me to jump in and do what I need to do. I'm currently adding some new features to my ECU i'll post these shortly.
James
Edited by wracing
base-1
What fuels did you want to use? We used to run my old boss' car at 10.5:1 CR and with 3 bar boost. That was on Carless that was about £2.50 a litre, so dirt cheap for a good race fuel - or were you just trying to stick to V-Power or something?
wracing
Essentially yes with some additives. We have used avgas & E85 cost is the major player though. I have learnt enough now that we could make a "high compression" engine when/if we have to replace pistons we will be aiming for around 11:1. Fuel control and cold intake charge is the key IMO hence why VWs engine is so successful @ 11.1 but they use direct injection. Unfortunately there isn't enough space in the head to convert to direct injection :(
James
base-1
Christ, done pretty well if you made it to 1100bhp on pump fuel, even with additives. What boost was that on? (sorry if I've missed that earlier in the thread).
Sam
Direct injection has its downsides too. Sooooo many TFSIs (and others) have the old sludge buildup as there's no fuel to wash it away.
Saying that though, they are quick. A local guy here in Sydney (who works on my S3) recently done a 12.06 @ 114 on a K04 TFSI with bolt ons and a map. Quick is an understatement. Epic.
Many of the 1.8T guys are running 9.5:1 with the 2.0 crank with good results.
wracing
Ok well we have made some progress, I have started to rebuild the front of the car to allow the whole front end to be removed with a few bolts. Also moving the engine back and getting it lower in the car.
This picture showing the original gearbox position with some of the new steel work
I have used a modified sump spacer to make a dry sump pan the is incredibly low profile. It sits nice and close to the crank and still allows room for our crank scraper
Engine and gearbox fitted up and mounted.
A few more tubes to be added still and I still have to fabricate the gearbox mount. Everything will be fitted to this frame everything from intercoolers to exhaust.
James
wracing
More work this evening. Mounted oil filer, cooler & pipework. Fitted the charge cooler into position. Started on the gear box mount but have just give up for the evening.
lol
James
dav1
this is clearly going to have some power if you get it to work together. Good look. Look forward to seeing more.
wracing
Small Turbo mounted today and most of the turbo cold side plumbed up. Its all got to come apart again for cleaning and painting but we are getting somewhere now
The new bypass valve is hiding in the background
Hot side plumbing only thing left to do here is the wastegate, antilag ports therocouple and afr bungs but these will be done when i wrap the manifold
more hotside
intercooler and radiator positions
thanks
James
dcc
I don't like it.
The turbo isn't HUGE enough.
Bigger please.
wracing
lol :) soon bigger compressor, the exhaust is a little to big now
Edited by wracing
pugpete1108
so this is now twin turbo and supercharged?? how the feck does this even work?
mental james.
wracing
exacly the same as before we are just compounding the boost with the supercharger to see if we can get a little more area under the graph.
We are running a bypass valve on the smaller turbo as it proved to be a flow restriction around 6500rpm+
James
custard-rallye
This thing is mad love it. what box is it? A ldv one as I know ldv van ones fit Xu blocks
Edited by custard-rallye
wracing
LDV Pilot gearbox with the xud engine fitted. The gearbox is an R380 used quite a bit in the 4x4 world. The box weighs about the same as a complete be box, so a little heavier as it doesn't have the diff integral but we will see how we get on.
James
custard-rallye
Thought it was same box my mate was using in his locost build
wracing
engine sits a 14 degrees though which is quite handy
e8_pack
Top work fella, its great seeing something different. bit dissapointed that the earlier pics arent working.
wracing
I've just noticed that I use facebook to host they must have changed the URLS :(
Mods how can i fix this????
I have had to cut the bulkhead again im going to have to redo all the tunnel to accommodate the new engine location. :(
Engine, subframe and gearbox all in.
Rear subframe all fitted up and rear wheels on, Ill take some pictures in the week I forgot tonight.
James
Edited by wracing
peter
Howayyy more pictures!
Batfink
use photobucket instead.
shalmaneser
Are you dry sumping this? Not much oil to go around if not....
wracing
Yes it is dry sumped
James
wracing
Progress over the last 2 weeks.....
Tunnel wider on the drivers side to accommodate the exhaust. Painting as I go, I want a black interior as orange was just to bright :)
James
Edited by wracing
