pablo
[misc_work] My Turbo 205 2.0 8v
pablo
nope the std ones are black with a blue ring. Not sure on the rates but think its around 200cc. Must look it up.
pablo
interesting info (to be confirmed), but the ohmage is different to what Im using (15.9). And the flow rate is crappy on the stds.
Part number - Lucas D3172MA
Flow rate - c180cc/min at 3bar
Resistance - c17.2 Ohms
- High impedance
As fitted to (examples)
- Peugeot 406 2.0 8v SRi Turbo.
Edited by pablo
danpug
Mine are cream as well?
danpug
Something sounds a bit wrong, they are supposed to be bosch injectors as standard.
danpug
And yes i see another seller is selling the same ones, i'm really confused now!
pablo
could be a load of pish then!!!!
wonder what the bosch part number is for the std 406 sri ones then?
pablo
well had the out for a scalp there. Not going bad for a first attempt. Pulls real well but I think I need a new inlet manifold gasket as the revs are bouncing a little while its idling only settling after about a minute. Was hoofing it up the road and it cut out a few times on full throttle which was a bit worrying but its only on full throttle, a little before is fine and the car flies so I think I just need to limit the throttle pedal a touch to stop it cutting out (TPS going off the scale?).
Another issus is that after lifting off after full power and coasting for a few seconds the car with splutter a little once I go back on the throttle. Go a bit harder and its fine. No issue when doing the same but only part throttle then lifting off. Hope its just the gasket causing it.
All in all pretty pleased will try to get the niggles ironed out and RR it on saturday morning. Want to make sure its still fuelling ok or its bye bye pistons.
danpug
Hopfully it is just the gasket. Are you going back to the same rollers and running the same boost?
pablo
same rollers, boost will be different tho as Im using an electronic controller now :lol:
new gasket ordered so get it chucked in on friday night and see if it helps.
danpug
What boost will you be running then?
Edited by danpug
pablo
probably 0.8/0.9/1.0 bar.
When the gains stop thats where the boost will sit. No point running a bar if youre only getting 1-2hp more than 0.7/0.8bar.
danpug
True. Make sure you post up theresults and also at what boost the gains start to become minimal, if you can of course!
pablo
had it out again tonight. Running a bit better after I left the battery off all night but still not great. new inlet manifold gasket ordered in case its a leak. If its no better Ill be putting the std manifold back on again :lol:
danpug
Did you re-use the old gasket?
pablo
yeah, and it was ripped a bit :lol:
danpug
Sounds like the culprit, fingers crossed.
pablo
Well a new gasket made no difference, so I swapped the std manifold back on and it ran perfectly straight off. So looks like project gti6 throttle body is a no go.
what idle valve is there on the gti manifold that's had the gti6 throttle body fitted? no reason why it wouldn't work over the turbo manifold.
pablo
Im stumped to be honest, using the same idle control valve, and throttle position sensor. But it wont idle (bounces in the 1000-1500 bracket) and is a little tetchy on the move when you suddenly floor the throttle etc.
same injectors and getting a decent map signal?
pablo
yes same fuel rail & injectors. MAP sensor fed from one of the side ports in the manifold.
danpug
Doh. did you bother rr'ing it in the end then?
pablo
no mate didnt bother.
