Swazy
[car_upgrade] My Mi16-conversion Euro-style
Swazy
My damn MI-engine missfires under load :) after some seconds it runs nearly normal but it needs its time
if i´m opening the throttle it won´t rev directly
There´s nothing the engine could get some fault air, everything is closed.
dizzycap is new, plugs are new, module and coilpack are also new :(
This car is making me ill :rolleyes:
http://img364.imageshack.us/img364/9008/img020ds2.jpg
Edited by cybernck
image filesize way too big!
cybernck
is it able to rev high when you apply the throttle very slowly?
have you got spare Air Flow Meter and Crank Angle Sensor to test with?
is your Throttle Position Switch correctly setup (clicks on idle and unclicks when the throttle moves)?
paul_portsmouth
what are those wheels?
if its under load is the ignition timing and fuel mixtures set up right?
Swazy
these wheels are from RSL Motorsport
@cybernck
no spare there for afm, but afm works :rolleyes:
paul_portsmouth
how did u get those wheels in a 4x108 it only lists them in 4x100 on thier site
Swazy
Well, probably they took the 4x108 out of their range?!
take a look at ebay germany, there you can get them i think
RSL at ebay germany
they say that are the last 5 wheels in 4x108
Edited by Swazy
Swazy
If i apply the throttle very slow the engine will rev higher but very very slow. If i hold the throttle position at its point, the engine revs quicker ?!
Swazy
New pics at my imageshack-site, take a look and leave comments :lol::):)
Swazy
Quick question. Could somebody tell me wich injectors will be best for my xu9j4 mi16? i think i need new ones
cybernck
well that's pretty obvious really... new or refurbed XU9J4 injectors.
Swazy
Ah ok, i thought there will be something better from aftermarket. But ok :)
Thanks a lot
Swazy
Ah ok, i thought there will be something better from aftermarket. But ok :rolleyes:
Thanks a lot
New parts for my exhaust system has arrived, all stainless steel
kyepan
have you seen the caps program on the xu servicing forum sticky, might be worth checking that the AFM is sending the correct voltage signals, it can easily be back probed with a multi meter, takes 5 mins and an assistant to hold the revs at a particular point.
cybernck
ooh, nice, Simons is a popular brand in Holland too from what i've seen :D.
out of interest, how much do the manifold and middle box cost?
Swazy
ooh, nice, Simons is a popular brand in Holland too from what i've seen :rolleyes:.
Well the manifold came from Terantex aka boeseturbo and cost me ´bout 700 euros, the middle box cost ´bout 100 euros
Swazy
Well, after i wasn´t able to get the Compo TH Mono street legal here in germany is was searching for something looklike and found these here:
This pic is taken from the web, mine are silver sprayed.
After i took of the silver paint, this yellow with the letters came out as you can see on the pic.
But i´ll polish them cause it will match better to the car i think.
Swazy
Not so easy to get off the paint of the wheels as i thought.
This is how they looked as i get them:
After 5 hours one!! ^_^ looked like this, nearly ready to get polished
Not so great looking like the th mono´s but nice, what you guys think?
And of course, a new caliper in the back was a must :)
Edited by Swazy
Swazy
I decided to bring my car to a friend, he´ll install a vems ecu, tb´s, finish the exhaust system and do they fine adjustment on rolling road.
So i hope the engine will run properly when i get back the car
Interior will be finished in some days, seats in etc, pictures will follow, has to tell my friend to do some.
Wish me luck that the car will go like it should do :)
Swazy
4 days left till we get the car 750 km to hamburg, my friend Jan is already waiting.
The the car will get a new MS2 ecu and set up on rolling road
I´m a bit nervous about it, i hope the car will run properly after the session, it will takes about 2 weeks
Jan will finish also the exhaust system :rolleyes:
Swazy
Well, finally i´m back at home. We did over 1500 km in 24 hours to bring the car to Jan.
It was a nice trip as well, but a lot of km :blink:
It wasn´t easy to get the car on the trailer cause the car was too low :D
Finally we did it B)
Swazy
After 5 hours one!! :) looked like this, nearly ready to get polished
After some weeks the wheels are finished, not chromed and not polished, they are high polished consolidated :D
Lovely :D
Swazy
My friend Jan has finshed the exhaust system yesterday, looks great i think.
Nearly every part came from TT Turbo, his own company. All stainless steel with a 4-1 exhaust manifold.
Fits excellent this backbox from Devil France
Swazy
Nice wheels right?
Gentrix
need to see them on the car, but looks very promising so far.
andi
Swazy
andi
Stimmt, sieht wirklich vielversprechend aus
