bigearmuffs
[Body_Work] 205 Wide Arch / T16 Project
bigearmuffs
Dip in top of arch (marked for filling)
Top of arch low instead of being rounded (in comparison to finished side)
Bottom of arch also low in the middle (marked for filling)
Roughly sands front arch back to shape
Roughly filled low parts
Seam Sealer turned up in post
bigearmuffs
Good news first, finished sanding the low bits both top of qtr & bottom, aside of fine filling and sanding they are done, only remembered to take a pic of the top part
Then major bummer, on test fitting the rear bumper (which needs loads of work) I noticed after much measuring the arch on the finished side falls half an inch short of the other one.... A didn't fancy cutting the unfinished one back so had to fill the finished one, fortunately with using cellulose it should blow in when finished
Usual filling problem of to damn much, another two hours sanding tomorrow
Side skirt fine filling and fine sanded, all good and finished
Stephen W
Looks like your doing a really good job on this and it's showing your enjoying it. Although the colours not my choice but I look forward to reading your updates.
Keep up the good work
bigearmuffs
Spent forever cleaning the garage out, it had got to a point were I could not find anything until I nearly broke my neck by falling over it. The dry sanding hadn't helped matters, once tidy and washed out carried on -
Back qtr now done as far as I can see, although once I prime it I'll soon know otherwise (due to all the different levels it does not look good in the picture at the moment, feels smooth though)
Done the other Qtr in fine filler and fine sanded, hopefully good for a coat of primer then back on with colour (now identical to the other side)
Front bottom of wing now meets the skirt better and ready for primer
All masked our ready to go
Will try and get some primmer on tomorrow, then might leave it for a week or so as I need a break from it
Edited by bigearmuffs
bigearmuffs
All blown over in primmer, still bits to do, can see them clear as day now, but mainly fine filling
Worth doing though so I can look at the profile down the side, I think it looks great looking down it, should look even more so with the doors on
bigearmuffs
After losing the will with filling and sanding every night I looked for a pick up with the bonnet, decided to go for the finish so on with 1500 wet and dry then down to 2000, after that t-cut and then polish, all of which took 2.5hrs..............
The result -
Compared to when I had finished painting and it was unprepared -
It's given me the lift to get the roof done, the side will have to wait.
jonXS
Looking good mate, keep up the good work i like how this is going.
bonnet looks better in the pics than it did, fair play to you
bigearmuffs
Roof finished same way as bonnet, sun roof fitted back in. Quite pleased with it on the whole.
Seeing as I am waiting for more paint supply's I am on with the crap jobs, need to scrape all this sticky stuff off so that I can reapply some double sided tape to refit. They are the strips that go at the top of the door frames.
Joy!
Juttie205
10/10 for effort mate still not sure of the colour may look better once car all back together.
BusEngineer
Great progress, hat off to you for doing your own paint and you certainly have more patience than I do with filler and sanding!
bigearmuffs
Have basically not stopped on the car since starting the holidays ,
Cleaned all the old stuff off and applied new double sided tape -
All bits of trim, etc are firstly stopping off for a quick scrub in the bath, then on to rest in the man cave, new bulbs fitted in the lights -
Had to clear the garage to get the work horse in to leave the path clear for Christmas day visitors, so hear is the car as it stands, all has a couple of coats on but need to get more on -
Ignore the overspray I will be painting under the arches black
Will get set back up for spraying and back on the job Boxing Day, I want to get all the paint done (including doors) before I go back to work in Jan.
lewis205cti
Impressive work mate. Some serious dedication and it's going to look awesome when finished. So jealous of your garage too.
allye
Looking forward to seeing this unfold, have you got a wheel choice?
bigearmuffs
Not decided yet, need to start saving some penny's cause everything next will be more money than effort - unlike the body. Need buckets, a cage of some sort, harnesses, wheels, suspension, etc. With it being a bit of a small budget hobby I will have to keep an eye on the usual places and hope for a bargain
bigearmuffs
Thanks for the comment, there was loads of fine filling, primer and repeat but it's getting there now. The garage is good I have to admit, I have done bits before in a small single or path at previous houses and although it can be done it does take more patience and organisation.
johniban
im very impressed with the amount of work you have done in that little garage!
i cant help but think all that work has gone into it and that silly exhaust is hangging off the back end?!
Personally i think something a little diffrent maybe cut the tips off and make one tip? or a slight angled 2.5 inch tip out the fog light hole or a centre exit maybe
bigearmuffs
Front panel masked and primed
Inside tail gate same -
Need to get colour on both to move on
please not black arches, always looks like someone is trying to hind shoddy work when they do that, which from the rest of the work it certainly isn't !
Juttie205
I can not see the logic in doing wheel arches black as you took the time to do all the rest of the car would be just as easy to do arches in green are you removing engine and doing engine bay that green?
I would hope he is removing the engine at some point, seeing as its a small TU :P
bigearmuffs
Cheers all, what you'd do under the arches green ?, I was just thinking of the black chip paint stuff. The engine bay will be green at some point in the future but I am getting the car back together first as I am running out of space. Got to remember this is a low cost sort of hobby past time, cheaper than drinking at night... Appreciate comments though as if you think it's worth the extra effort I may give it ago. Just put a couple of coats of green on the front panel and inside tail gate (will do the exterior when it's back on the car).
johniban
id personally do under the arches green, you can still spray stonechip first so the paint is slightly flexible to stonechips. wish my project was cheaper than drink haha
Juttie205
Under arches i would use a white or grey stonechip then cover with a base colour thats what im planning with my dimma so arches match rest of car.
pugfrank
What a great project, cant wait to see the finished item.
bigearmuffs
two coats of green -
