layton1985
Who Has Converted Their 205 To 2.0 8V Turbo?
pugdamo
If your top mount bolts to the engine with 2 allen key bolts and 2 16mm nuts directly behind them you need is the 306 gti6 or a xsara VTS,thats the type i used on mine
that's the 406 one, 605 used the one with the 1.9 MI type bracket, miles uses them as they're a decent bit lighter.
Ryan_g1
If your needing an mi16 top bracket, I have one I no longer need as I have the 406 mount on mine now. £25 delivered.
Also does anyone know the pin data for the vss as my autodata isn't working.
Slo
Ill have it but let me put a picture up first to confirm 2 tix
EDIT: to add picture
Edited by Slo
pugdamo
Mine is a 605 engine,maybe my mount is like that as its one of the later 605's?
Jemehan
That is one beautiful looking clean and tidy engine bay - ENVY!
Ryan_g1
Yes mate the mount I have here is the correct one for your engine. Drop me a pm if your wanting it and ill get it posted out ASAP.
unlikely, there's only the alloy type listed, did you remove it yourself?...
pugdamo
Yeah i bought a complete car,its a P reg SRTI
Slo
New clutch has come and it doesnt fit ffs its only 205mm the driven plate wont fit on the splines and the pressure plate doesnt line up with the flywheel back at work tomorrow for 6 days AARRRRRGGHHHHHH
Slo
Rang up to moan about the clutch and the seller admitted someone has balls'd up and sent me a 259 kit instead of a 529 kit (their numbering system), result = sending me the proper one by overnight delivery and i can keep the other one FOC so if anyone is after a brand spanking full astra clutch kit 86-91 ive got one ;)
Slo
Got the correct clutch now and have hit another snag the torx bolts are too big for the mi16 flywheel, the ones out of my 205 (13mm nuts) are also too big. BUGGER. Are these 12mm nuts/torx equivalent?
M7 Allen headed bolts.
6913 98.
£1.50 each
Slo
Can i use 11mm bolts with washers and thread lock as they fit
if they're clutch bolts yeah, if not I doubt they'll be strong enough.
Slo
Mmm was just clutching at straws there really oh well another session wasted and so close to bolting the lump in
got any other engines lying about with clutches on? same as XU7/10, XUD9T, TU1/3.
Slo
Only the turbo engines and this 1.9 ive asked speno if hes got any laying about failing have a walk over to peugeot in the morning
EDit: Can they be drilled out and retapped or will the threads be s*ite? or is the steel too hard to tap
Edited by Slo
dcc
just buy the right ones. shouldn't re use them anyway.
Slo
I will do. Just a bit miffed that they changed the bolt size on this mi16 to thinner bolts yet the others are the same, theres a big difference from the 2.0 turbo clutch to the 1.6/9 yet same chunky bolts
Is it these bolts?
Edited by Slo
No, they are 30 mm long from tu5 engines, you need shorter.
Just get new :)
Ryan_g1
I drilled mine out and tapped them without any problems Andy.
pugdamo
Iv got 2 bolts,can send them up if you wanna pay postage,should save you buying 2 packs.
