MiniGibbo
[misc_work] Minigibbo's '93 Peugeot 205 Rallye.
MiniGibbo
I really want arches but then I also really like the lines of the base model :/
Lowercase
know what you mean mate lol. i have a set of arches in the garage, cant decide whether to go euro spec or not lol the euro spec looks less 'racecar' to me for some reason....
MiniGibbo
Had the car weighed this morning, as I always do..
Full tank upto the filler neck
Same weighbridge as usual
Came in at bang on 800kg which from my other thread comes to the conclusion fuel is around 35kg so say 30kg fuel out leaving enough for a couple hot laps on any uk circuit. Leaves me at 770kg which with my 100hp (could argue more with breathing mods) at 130horse power per tonne.
Bang on with a 106gti/Saxo vts.. Fair enough :)
Lowercase
weight of powerlifting driver....
MiniGibbo
I always get rinsed on the BMW forums about this haha
I've gone up a weight class this year so since November I've packed on nearly 10kg haha
MiniGibbo
Went to castle combe yesterday for the spring action day, this was my second year and yeah its a quiet show but I enjoy the mix of cars and its an excuse to have a quick blast on track haha
As my other project is still away I took the 205 and used it as a final send off for the 1300 alloy engine :D Ive been driving the car a lot lately and its been faultless.. pure smiles per miles..
I went out for a single slot on track as I really enjoy combe and the car didn't disappoint.. yeah everything over took me down the straights and its a full road set up so the tyres, 'soft suspension and oem brakes slowly give up but the balance of the car and the way it took the corners really really impressed me..!!
Id love to see how a well set up 205 could take the track..!!
few shots the girlfriend got as I passed
And a quick drive by in the crowd
We came home past a route I took for over a year coming home from work and always wanted to photograph.. quick shot with the 205 :D
Which leaves me with throwing the timing belt on the 1400 and starting the engine strip after breakfast today..!!!!
MiniGibbo
Started off finishing off the XSI engine this morning, new water pump and tensioner..
old vs new
Then fitted, I tried to fit the back belt cover that has to go on before the alternator pulley but for the life of me cant get it any of them to fit... im wondering if the set Ive kept for this engine didn't come with the engine but my old XS engine and they differ in mounting..?
but either way new shiny bits fitted without the new belt
Right after that, down to real business and I started taking the car apart with care... With trim and the rad out the way, out come the white tape and permanent marker to label absolutely everything haha
All went pretty well, came to conclusion the the inlet will need to come off so I can properly access the loom behind the block, had the injectors out to see they've been sealed with what looks like bathroom silicone.. guessing this is because they leaked..??
How should they be sealed properly..?
Also blocked off the fuel lines as I guessing this is a good idea while its in bits..??
Got the inlet ready to come off sensor wise but got stuck with the throttle cable.. have no idea how to remove it...?????
MiniGibbo
bit more progress on the car today, got all the loom labelled and off the engine,
Got stuck again though.. I don't know how to remove
Cutch cable
Speedo cable
Gear linkages..
Advice please..
baffled how you got this far if you cannot figure those out, you don't need any tools for two of them even :P
throttle cable unhooks, speedo cable you pull the rubber wotsit out then pull upwards, clutch cable just slacken it off and lift out of the clutch arm and push the rubber grommit out of the bracket, unhook off pedal and pull grommit out of bulkhead.
MiniGibbo
Slow and steady haha.. I've learnt more about 205's in the few hours I've spent doing this than I have in the entire ownership of the car haha
MiniGibbo
Put another hour into the car today and the engine is nearly ready to come out. started looking at swopping stuff from the rallye lump to the XSI lump and come to my first hurdle...
The rallye has a oil cooler and the XSI dosent... I thought it would just unscrew off the rallye and onto the XSI but they differ..? am I being simple or wont the cooler fit my new lump..?
Rallye
XSI
advice..?
Itll fit fine, you need to remove that short threaded piece
MiniGibbo
And done..
Also got the drive shafts out so it is now literally unbolt the mounts and its out :D
MiniGibbo
Well today is the day..!
Decided to take it out the bottom and it was going really well until I craned the car higher to remove the engine from underneath and the engine fell over.. it only broke this pipe though thankfully which is a removable part..
and out :D
Got my detailing work cut out for me :/
Visually compared the engines for the first time to come across my first problem... the alloy engine has a (now broken) external water pump but the cast engine doesn't and I don't have what ever bolts to the block :(
Advice..?????
Anyway though, carried on and had the box off,
And a quick finally shot of them together,
MiniGibbo
As im struggling to locate the bits I need I thought id turn my attention to the bay.. it was clean'ish but not upto par so out came the snow....
After some scrubbing and a rinse,
terrible lighting which gave rubbish photos I know :( the finish in person though did put a smile back on my face until I turned around to see the engines again at least..
MiniGibbo
Good friend of mine fitted my Grp A fork bush for me this week,
Some people dislike stiff bushes but I run them in other cars of mine and personally love the added feel and reassurance they give :)
jonXS
^^ Me love bush :) :)
MiniGibbo
Thanks, got a box of bits this morning so got them fitted this afternoon..!
Starting to look like an engine..!!
then fancied doing a bit more on the car so fitted the bbm engine mounts, new vs old
Next up im waiting for a complete cam belt cover set to arrive and I can fit the belt then look to put the engine in :D
MiniGibbo
Few new bits this week, Brand spanking dipstick a both of mine have seen better days
Also have eight injector O rings on order at £3.08 each #cringe
Got the timing belt on, engine manually lovely.. nice and smooth..!
Followed by a new set of covers
Then the alternator off the 1300
or some reason no one local has normal spark plugs in stock so I had to bite the bullet and buy "performance" plugs :/
Stuck a few more plates and sensors on the engine and ended up looking like this for today..!
Once the rocker cover is painted itll be ready to go in..!
MiniGibbo
Continued today,
Fresh rocker cover and new rubber gasket
Which allowed me to finish off the coil pack and leads
Ahhhhh here we go again
until I went to stick the clutch on and realised Im kidding my self thinking id get away without a alignment tool haha
Not long now :D
Lowercase
you dont need a tool. just jiggle it. we did mine on the floor without a craine
poof :P
dcc
I think I used a 1/2 extension bar to fit my clutch! :) - then saw the clutch tool I had years ago in one of my 'spares' tubs :D
as above! bit of tape wound around the shaft to make it fit snugly in the friction plate.
you can also see the edge of the friction plate around the sides, match it up here before fully tightening the pressure plate bolts, thankfully the MA box is quite light so its no big deal if you have to jiggle it about a bit.
jonXS
I used the end of a broomstick, shaved down to fit snugly. Its worked everytime for me :)
looking good though
MiniGibbo
Thanks for the tips guys.. I went out and bought a kit earlier though before reading this haha
