tdr_1976
[rally_prep] My 205 Constantly Evolving 205 Xs Road Rally Car Project
xs already has the sport gear cluster doesn't it?
tdr_1976
Hi Mei,
I think it does. I used to have an excel file with all the ratios on it, including the XS's one, but I lost it.
The one I found on Google hasn't got the XS ratios on it :(
It would be good to find another as I can compare the ratios between the GTi/VTS and the XS clusters.
And
I am sure there is only 2 gear sets in the ma both have the same 1st and 2nd? Just different 3-5th and final drives the xs should have a 4.2fd and lower gear set the final drive is also found in a 5dr saxo 1.1 but the poor ratios some 1.1 206s have a 4.5fd
tdr_1976
Checked my striped down XS gearbox earlier on this evening, the FD is a 4:2 :D
samthornton1990
Just a heads up, the JP4 cam covers fowl the bonnet, best off sticking with the metal J4 ones. Ended up grinding one of the braces of the bonnet on my GTI and it still rubs.
the one place where an 'auto' bonnet probably helps !
samthornton1990
Well said that man! I'm just a stingy bugger!
tdr_1976
Thanks for the heads up mate!
My mate's got a J4 converted 205 Rallye with the JP4 covers, and he's got an auto bonnet on his for clearance.
I'm not a 100% sure what to do yet, but it's likely that I'll stick with the J4 ones - Are they really a bugger to seal up? Heard they are a problem!
Edited by tdr_1976
they are a pain in the arse, no replaceable seal, just a bonded silicone strip, thats why the JP4 covers are much better with the replaceable rubber seals.
tdr_1976
I've decided to go with the JP4 covers and leave the coilpack cover off for now.
I do have a question though - Relating to the oil filter heat exchanger, I've noticed that some of the J4 engines don't have them, an the JP4's dont? Can I run without it?
you can run without just fine, i prefer to keep them as they aid warmup, if oil temps become an issue you can always add sn air-oil cooler on top and use a half height filter, found on early 90's renaults.
a common arrangement to find on peugeot and citroen sport rally cars.
tdr_1976
Thanks for the info Mei, much appreciated!
I'll keep it on, I've already got a new seal for it, just need to get a pipe with the offtakes for it :)
tdr_1976
Some progress photos from the last few days :)
GTi Gearbox cleaned and painted
15267715_10154232473807861_8806882431370​
15338897_10154232484477861_8830755504142​
I got lucky last Saturday and got my hands on this Genuine Peugeot 1.9 Brass Radiator :)
15326492_10154256308962861_2842345240902​
I also got the cylinder head back :)
15319032_10154256328822861_3171195559259​
15317823_10154256336717861_8354910509274​
15442195_10154256337602861_6157611490137​
Catcams 708's Fitted
15337477_10154256340722861_3670127347947​
Exhaust stud kit fitted
15380567_10154256342377861_6129226957808​
Covers on to keep the dust out !
15390965_10154256349317861_5052048447531​
tdr_1976
Just took one of the new head bolts out of the box and found that there's no spacer on it.
It's exactly the same length from the base of the spacer, I think it's ok but could do with a second opinion before I go ahead with the job later on.
tdr_1976
Another update.
Got the engine rebuilt, after I decided against using the cylinder head bolts without the friction washers on.
A few progress photos of the weekend before last;
15400505_10154264486307861_2372215602583​
15380825_10154264486777861_1755832359888​
15400494_10154264488232861_1130973388065​
15390668_10154264491242861_1063527301782​
15589824_10154280417002861_5928086088057​
15542412_10154280417012861_6361981339025​
15590421_10154280417017861_2355069927859​
15621639_10154280416987861_1441439138289​
trogboy
Looking tidy!
tdr_1976
Cheers chaps :)
A few more photos to add from last weekends progress;
Engine and box bolted together, on the engine hoist ready to go in
15541461_10154283182242861_3421112731487​
15625887_10154283182532861_5620314050974​
15591565_10154283182197861_5854128669849​
15577990_10154283182452861_8783765948516​
15625859_10154283182282861_8646646631718
15590994_10154283182207861_7230357618395
That's where it's up to at the moment. Got a lot to do still, sort the wiring loom out, make an exhaust manifold, replace the xs tank with a GTi one, run a return line from the engine bay to the tank, oil catch tank etc etc.... will keep updating this as I go along :)
Edited by tdr_1976
Graz
Does the lightweight crank and alternator pulley gear down the alternator so it produces less power? Not exactly what you want with a big pair of spots or have you figured out its not a probelm?
I always come to your thread for inspiration for mine.
tdr_1976
Hi matey, I'll find out when the project is completed and have the spots fitted for testing :)
In the meantime, I have the small matter of sorting the wiring loom out...... not going well at all at this stage.....haha!
15672982_10154306864502861_1895549912175​
toolie72
Looks standard-well done that man
tdr_1976
Thanks mate!
Made some good progress today, modified a 106 induction kit to fit, and fitted the new oil catch tank and pipes;
15781269_10154319828437861_9202381617196​
15747879_10154319826307861_6819059405634​
15781014_10154319827662861_6551161874313​
15780635_10154319827287861_1784386861126​
15823578_10154319827162861_5367692672541​
​15823397_10154319826902861_4813465435073
15726262_10154319826797861_4160130664091​
15781762_10154319826367861_8841828303898​
opticaltrigger
Very,very nice Dyl.
O.T.
no breather on that can? I think you will need to tee the two hoses together and add a breather filter to one of the two ports.
far too shiny for a rally car :P
tdr_1976
Hi Mei, I'm going to add a offtake for a filter on top of the tank :-)
Edited by tdr_1976
