rossi
Gti6 Lacking Spark
Spiky
nothing wrong at all. Just dreading doing the wiring! I'm gona start it this weekend hopefully. I take it its best to do the looms with the engine out?
if you want the send the 205 loom (two brown connectors) and gti6 loom, i'll mate most up for you????
i did my conversion, with engine and loom in the car (205) and just labelled the wires up and soldered them together
Peetypug
cheers for the offer mate :) may take you up on that. But first i want to see if i can do it myself. I've got wiring diagrams off here so will have a look at those first. Thanks again
Spiky
ok cool, label them up esp the 306 loom as it has numbers on each cable
it's easy then
rossi
Well impressed Spiky, what a shame that had to happen though with the exhaust, brake/fuel lines. Bummer! There's always sumat!! I'm just over the moon it actually runs, after all this time! There's a lot of doubters who i know, but anythings possible! Cheers spike, good man!
Spiky
hopefully by the end of the week, (baby pending) i should have it ready for you
no when i say ready, as much as i can sort for you
rear brake is an issue and drive shaft.
but fingers crossed we can sort most of the rest out :)
gti-si
Well in mate, glad you got it sorted!
Spiky
well all the wiring now pretty much complete, except the reversing lights, (never got them working on mine either..lol)
so here are some pics from tonights progress
just awaitint a oil pressure sensor from an S16, so he can have a working gauge, then i can fit rad and see how it is :)
Spiky
oh and the rev counter works too :):P
rossi
You're dam good, i cant believe the footwell looks like that now haha. It's like it has never been fondled with! And the engine bay.. 1000x better, soo not used to seeing it like that heh! Brill!
ECU on the usual position under the dash by the steering column?
Spiky
god no, as i'd have to extend every cable
lol I cant see it in the engine bay that's all haha!
Spiky
lol...
it's sat on the roof of my car :)
it will some how fit under the expansion bottle, no where else to go
Phil H
Great post to read, well done to all concerned for resolving the issues. Group hug time ?
Spiky
ok, final touches tonight
had ir running, and it holds water, not run it hot hot yet thought
the exhaust needs work, as i thing the downpipe to manifold needs work and the joins need work, but thats somethig for rossi to sort once he got it ;)
but the dredded mechanic strikes again ;)
i thought the engine sat a touch to low, so i took the engine mount off, see if you can see the problem in the pictures,
also noticed he has exteneded the bottom arm to much so another small job for rossi
the rear brake line i have crimped, but i'd not like to drive it like that
the fuel pipe is a bodge to get it running too, so again, needs sorting
need an air filter
also needs the ECU mounted secure, as i have just cable tied it in place
but on the plus side,
ALL the gauges work, it ticks over fine,
Henry Yorke
You want ot look for a plastic battery box from a 306 to mount the ECU in the engine bay, You can see it just behind the battery on this pic with the blue diagnostics plug in the top of it. I had to move the expansion tank slightly left ot get it to fit snugly, but it makes it a lot more watertight and factory looking
rossi
Well, the pug is back with me and i'm chuffed to bits with what spiky's done. Really good work, It fires up straight away, no hesitation. Still a fair bit of work to be spent on it, but at least the tedious part (wiring) is 99% complete!
Gave it a well deserved wash today, 1st wash in waay over a year heh.
My BBM kit came today but no one was there to sign for it :)
I'm looking for some gti6 brakes in time, so if anyone has some for sale, give me a bell.
