rossi
Gti6 Lacking Spark
rossi
Thanks matt, you're a star!
gti-si
Spikyu, sorry to hijack this thread, but the big earth that you've got coming through the bulkhead...where does that go?
Spiky
rossi, i might be picking up tomorrow, if matt's home, :D
Spiky
i didn't really to send it though, as it;s only and earth, but i will just mount it on the body near the ECU somewhere
one thing this car needs a new earths and they shocking...lol
rossi
The mi16 box has your name written all over it lol! Thanks again
Spiky
sweeeeeeeeeeet :D
Edited by Spiky
Matt Holley
I have pm'd you my number, I will be home or not far away most of the day :rolleyes:
I have just dug the loom out and I also still have the tdc plug that was cut off, I forgot I did it, but I even labled the loom plugs before I took it off the engine :blink:
Spiky
ok little update from the weekend
quite a few wires been removed from the car now ...lol :D
loom not finished, hence some cable just together, but most are solder and heatshrunk :wub:
and it's a LOT bette under the dash now B)
rossi
It's crazy how you got it looking like it is! Even if it stil isn't running. That b*****d mechanic told me that the system would require a radio for the car's circuit to be complete, is that a load of bullmuck? It got nicked ages ago during the whole conversion, along with the fuel off some scallys.
Oh and matt, thanks a LOT for that loom (Y) :D
Edited by rossi
gti-si
Rossi, I think the simple solution may be a case of the mechanic isn't a mechanic?! He's talking rubbish. Seems he didn't understand in the slightest what needed to be done. The engine management loom and the car loom are entirly seperate, they even come out of different holes! You don't need to touch the car electrics during the conversion.
Spiky, Just like to add to what Rossi said, looks like you've done a marvellous job getting rid of those nightmare wires, I know its usually quite simple to remove the old engine management but not in that case, it was butchered!
Edited by gti-si
Spiky
a radio??? unsure what ya mean..lol
i hoping it just needs petrol and will start..lol
yeah, your under dash looks much better now and once i tidy'd up the cables under the bonnet it will look complete, bar some TLC B)
Spiky
tottally agree on the fast part dude B)
even i'm not a mechanic, but he must have been blind
and thanks for the second part :D
rossi
  Spiky said:
bar some TLC :D
ie, CV boot and fuel pipes? hehe
Matt Holley
No probs, glad I could help B)
Spiky
WELL FOOKING HELL
decieded to have a night on the car and get it running at all costs :D
so
put my ecu on, NOTHING
put my internia switch NOTHING
fuel have it's own battery..lol NOTHING and still sounds weird :)
my double realy NOTHING
took spark plug out to check spark..HAS SPARK
so final thing was to check fuel in the rail
SO.
took the return off, was resting the return on the bonnet stay (as no fuel will come out of here)
then put a pipe ont he return of the fuel rail
and what do YOU think happened ?????
fuel came out of the return? if it does and it starts then there's probably a squashed pipe underneath the car?
Spiky
it dont start thats the thing :(
it DID come out the pipe that i took off the return :) and not the rail, so somewhere the pipes must be swapped :D
but, amazingly thats a good guess, B)
so went under neath to put exhaust back on and look where it much be swapped
and here's what i found :(
so the rear brakes are FOOKED, well at least the drivers rear is
the fuel pipe is kinked, and somewhere it's be swapped over(unless the pump is send fuel up the reserve?)
Peetypug
somebody needs to go round and see this so called "mechanic" :D
Spiky
Rossi, you must be the most unluckyiest person i know,
if it wasn't for bad luck you'd have no luck at all :D
so this must have happened when they took it off the trailer, as the mrs confirmed they rolled i off front wards, which is why the exhaust was ripped off, taking this lot with it :)
gti-si
Christ, that is some serious bad luck right there. You going to be able to sort it? I'd just cut that section an join it with some fuel hose and see if it starts with a good fuel feed? Or with it coming out of the return does that mean it should be able to inject?
Spiky
i did just that, as i had a small length of fuel pipe, i just come in now.
it's RUNNING, first turn of the key :D
Matt Holley
Well done spiky :D
Peetypug
well done mate. Fancy coming up to stoke to do mine :D. Where did you get you label making tool from? Think i might invest in one
Spiky
  sorrentopete said:
well done mate. Fancy coming up to stoke to do mine :). Where did you get you label making tool from? Think i might invest in one
whats up with yours??
its just use a dymo printer, then i use clear heat shrink to cover it :D
Peetypug
nothing wrong at all. Just dreading doing the wiring! I'm gona start it this weekend hopefully. I take it its best to do the looms with the engine out?
