SwedishBob
[project] Peugeot 205 Gti - Trackcar Project.
un numero d'or
drewling :)
dale205mills
Please hurry up and finish this car :D those wheels look the part and so will the car when it is done.
SwedishBob
drewling :)
:) You are more than welcome if you are passing Västerås.
I'm doing my best. :P
SwedishBob
Got a problem with my doors. They are aligned and got new pins. But they will not "close enough"
The brass thing in the B pillar is adjusted maximum inwards.
What I'm doing wrong!!??
Edited by SwedishBob
SwedishBob
Problem solved!
I had to move the "brass thing" outwards instead.
Conclusion: Don't drink beer and build cars.
Well, that doesn't make sense but it's good that you've fixed it! :lol:
SwedishBob
It's quite obvious when you think about it.
The doorlock is locking in two steps. If the brass stuff is too far away the second step won't reach the brass. Simple as that.... :-)
SwedishBob
Radiator and oil cooler relocated for the third time......
Front arches fitted. I might have to get a set of wider arches if I should run wih my SL341 and 406 Brembos..
SwedishBob
No major update but carbon fiber is fun, so here are some pictures.
Door cards:
1.jpg​
A sneak peek of how it gonna be with my rear mirrors.
​3.jpg​
Exhaust, 6-point + 4-points harness and a ECU is ordered and will arrive within 2-3 weeks.
SwedishBob
This beauty is heading to Sweden on monday.
mmt
GREAT BUILD!!!
How did you fasten the arches to the car?
SwedishBob
GREAT BUILD!!!
Thanks!
I used ordinary selfdrilling screws.
mmt
Thanks.
Amy paticular reason for using screws? I am thinking of using pop rivets on mine!?
SwedishBob
Thanks.
I had screws at home. Simple as that. :)
SwedishBob
Yesterday I loaded the car full, and went to FR Autosport Sweden.
A couple of hours later it looked like this.
And when it was unloaded into the garage.
SwedishBob
Mounted my new 4-2-1 manifold today but ran into some problems with my satchshift. <_<
Anyone else that have got this problem and if so how did you solve it?
1.jpg​
2.jpg​
​3.jpg​
Looks like a manifold issue not a satchshift one, 205 dowmpipes are always off centre in the exhsust tunnel, looks like a standard linkage would have issues with that manifold?
SwedishBob
The satchshift isn't the problem. The manifold is made the same way as Peugeot Sport and should work with standard linkage. What
I've heard. Will look more into this tomorrow.
SwedishBob
Sounds like a scooby at idle, love it :P
Haha...
SwedishBob
Received my new arches yesterday. And this is going to be great. :)
Old arches vs. new.
mmt
Looks WIDE. Are you painting Them white or leave Them black?
What kind of beam do you put on it in order to fil out the wide arches?
SwedishBob
They are wide. 80 mm in the rear. Will keep them black.
Are running a 309 gti beam and Speedline SL341 ET10 wheels. So spacers are required to fill out the arches.
mmt
Any news on this one? Where Are you:-)
Edited by mmt
