rally ax 0 Posted October 27, 2006 Blimey! Thats really what i want with my engine, good midrange, a good headline figure but not at the expense of a nice wide powerband.Just out of interest, would you mind describing your engine spec? What bodies are you running? Its not as exciting as you would think , Std XSI bottom end (un-touched),std flywheel with paddle clutch, Pumaracing std valve cylinder head, "mild" 280deg Catcam from QEP, Janspeed 4-2-1, inlet manifold from Bogg Bros, GSXR600 38mm ITB's with Ramair filter (bulkhead cut to get maximum intake length), DTA engine management mapped by Russell at Wallace Performance on a Dastek rolling road . Share this post Link to post Share on other sites
RossD 43 Posted October 27, 2006 Thats pretty much the same spec as my first build is going to be, bar the headwork and I'm going to be using megasquirt. Main difference being the Jenvey SF bodies I'm going to use are 45mm and using original injector locations in the head. Share this post Link to post Share on other sites
rally ax 0 Posted October 27, 2006 and using original injector locations in the head. Thats what I did ,saves alot of hassle (and £££ ),I used "black top" zetec injectors from a 2.0 Mondeo in a 16v fuel rail because the FPR is at the end rather than the middle .The std XSI FPR fouls the inlet runners because the manifold is angled up-hill to clear the horizontal part on the scuttle panel .(vertical part cut away) Share this post Link to post Share on other sites
christopher 5 1 Cars Posted October 27, 2006 Just as a quick sidenote, does anybody know what the most powerful 8 valve 1.4 N/A engine is out there? (TU or otherwise!) The guy with the 137bhp AX must be pretty close.... 205 Group A Rallyes come in about 140bhp at 8000rpm. They are of course only 1.3's (1294cc) running standard twin DCOM webers Share this post Link to post Share on other sites
RossD 43 Posted November 6, 2006 Well I now have a set of shiny looking throttle bodies (mmmm shiny things ), manifold, injectors and fuel rail from Sam. Now just need to source some XSi pistons and the build can commence! Share this post Link to post Share on other sites
Sandy 189 Posted November 6, 2006 Excellent Ross, i'll be very interested to see how they perform on a 1360 with decent compression! Share this post Link to post Share on other sites
RossD 43 Posted November 7, 2006 Excellent Ross, i'll be very interested to see how they perform on a 1360 with decent compression! So will I! It might have to wait for a while though now, some berk has just written off my 406 by running into the back of it.... I'm soooooo pissed off! Share this post Link to post Share on other sites
RossD 43 Posted February 15, 2007 Right, now I'm in a position now to re-start this project. Anyone got a 1.4 XSi lump they want rid of, or even just the pistons? I want to start building an engine soon!! Share this post Link to post Share on other sites
bren_1.3 1 Posted February 15, 2007 shoud have posted earlier buddy. just scrapped a block and crank as i hate cast iron TU's! and the pistons have gone into storage with one of them at trogboys house. would have sold you them otherwise. Share this post Link to post Share on other sites
RossD 43 Posted February 15, 2007 (edited) shoud have posted earlier buddy. just scrapped a block and crank as i hate cast iron TU's! and the pistons have gone into storage with one of them at trogboys house. would have sold you them otherwise. DOH!!!! I'm using an ali block hopefully with these pistons so the lack of a block aint a problem..... Edited February 15, 2007 by RossD Share this post Link to post Share on other sites
Sandy 189 Posted February 15, 2007 Those piston I had were absolutely shagged. Share this post Link to post Share on other sites
RossD 43 Posted February 16, 2007 I thought that might be the case Sandy, ah well, the hunt continues. If I can't find the pistons, I was thinking of maybe using a 1.6 block (heavier yes, but parts are much easier to find) with a 1.4 crank; obviously I'm going to have to research this a bit more, but its kind of a backup plan incase the 1.4 idea falls through. Only disadvantage (if it works!!) I can see is the increased weight of the block.... Share this post Link to post Share on other sites
trogboy 17 Posted February 16, 2007 the pistons have gone into storage with one of them at trogboys house. Is it? Did I only send the TU24 piston back? I've not seen it about but if I did have it I wouldn't have chucked it anyhow so it must be in the garage somewhere. I was just thinking about biting your hand off for those pistons myself now I have got the engine running and in the car - need something to keep the grey matter ticking over. Share this post Link to post Share on other sites
bren_1.3 1 Posted February 16, 2007 Is it? Did I only send the TU24 piston back? I've not seen it about but if I did have it I wouldn't have chucked it anyhow so it must be in the garage somewhere. I was just thinking about biting your hand off for those pistons myself now I have got the engine running and in the car - need something to keep the grey matter ticking over. yep you only sent the TU24 piston back over! give me a PM about them. Share this post Link to post Share on other sites
Jrod 7 Posted February 16, 2007 If you do go for a 1.6 block I have Sams old one here if you want it. It's free. Share this post Link to post Share on other sites
Sandy 189 Posted February 16, 2007 Overbore 1.6 block (eg 79mm) with the 1.4 crank would be good. 1509cc. Share this post Link to post Share on other sites
RossD 43 Posted February 17, 2007 If you do go for a 1.6 block I have Sams old one here if you want it. It's free. What type of condition is it in?! I will take you up on that offer, but I cant get down to Portsmouth for a few weeks yet. Looking at sometime in March? Anyone know what happened to that engine mount Sam had from the iron block engine? Overbore 1.6 block (eg 79mm) with the 1.4 crank would be good. 1509cc. Trouble is with that I'm then looking at custom pistons and things start to get expensive..... Share this post Link to post Share on other sites
Sandy 189 Posted February 17, 2007 There are numerous OE 79mm pistons about which could be used. Share this post Link to post Share on other sites
Jrod 7 Posted February 17, 2007 I have the mount aswell but I'm keeping that. I think the block needs a rebuild to be honest but I've never used it so have no idea really. Share this post Link to post Share on other sites
RossD 43 Posted February 17, 2007 I have the mount aswell but I'm keeping that. I think the block needs a rebuild to be honest but I've never used it so have no idea really. A rebuild doesnt matter, it would have one for my build anyway! Is it just the bare block or is the crank etc in it still? Share this post Link to post Share on other sites
Jrod 7 Posted February 17, 2007 Cranks still in, pistons etc all there still. Share this post Link to post Share on other sites
RossD 43 Posted February 18, 2007 Cranks still in, pistons etc all there still. Ok brilliant!! Share this post Link to post Share on other sites
RossD 43 Posted March 17, 2007 (edited) I started to strip down the block that I collected from Jrod a couple of weeks ago. (Sams old block). It seems to be in remarkably good condition. I pulled a piston and rod out this morning, pics below.... (Some are a bit blurred sorry) Only some slight visible wear on the piston, ring gaps seem very tight etc. Pulled a main bearing off and bearing seems in good condition. Will get the pastigauge on it sometime to confirm It's a 1994 TU5J2 (NFY) block from the ID marks on it, so from a 106 1.6 XSi. Edited March 17, 2007 by RossD Share this post Link to post Share on other sites
Sandy 189 Posted March 17, 2007 Yep, it came out of MattB's Diablo red 106 XSi. I had the head and gearbox at the time. Share this post Link to post Share on other sites
TKH 0 Posted March 18, 2007 (edited) edit Edited March 18, 2007 by TKH Share this post Link to post Share on other sites
