Karl
Had Enough Of My Gti6 Wiring Is Shocking
Spiky
its about 2", the 1" one has 4 wires and is the lambda
if it has about 16wires, then thats the double relay
Karl
ill nip out nd have a look now if i can see 1 min
Karl
yeh found it mate and its plugged in but dont know where the wires goits kind of a mess :wacko:
Spiky
have you got a multimeter to make sure pin 14 has 12v with the ignition on
Karl
lol nope.................
................................... bet your thinkin well what a useless t***
Spiky
get some wire and a brake light bulb then :P
i'm off to bed now
we can get it going, in the day light check all connections, esp one on top of gearbox and wiring aroubd gearbox :)
and
Karl
yeh sweet man thanks i will be on 2morro around half 6 - 7 after work ill try n put up sum pics or maybe a video sumwhere to show you waht im working with lol thnks alot tp guy :)
Sounds like a right hash, You really do need the Lambda sensor and speed sensor which I guess is not wired in. But as said the phase 1 is the easiest one to fit as you don;t use any of the 306 sensor loom wires all the 205 ones which are routed the correct way anyway.
Might be worth giving Constella a call as there Just south of Donington Park
damien
i would pull the whole loom out and start again/get a new loom from spikey/miles etc...
It's a phase 1 car so you cannot plug and play unfortunately, it as all the main sensor's are in the car and do not unplug unless you take a fair amount of the loom apart
Karl
right as far as i can see the everything is wired up im not sure ont the pin14 thing tho dont know how to test it tried using a light with somewire but the light has 2 terminals and wont light up on any of the pins on the double relay
Karl
ffs this is proper doing my mind in now i have no idea what im doing and it wont flaming start alilujah when it does get goin and is all sorte really appreciated all the help tho guys gdd job there is some proper decent people around willing to help and sahre knowledge
Spiky
Ram a bit of cable into pin 14 then get another bit of cable and attach to an earth , turn ignition on and attach the two wires to the two terminal on the bulb, well side and one terminal it should light up
Karl
will do it in a min how do i know which 1 is 14
Spiky
When the relay is removed you will see they are numbered :)
luke1987
Heres the wiring diagrams if there any use to you mate. Ones the early loom and the other the later.
Hope its some use to you.
early.pdf
late.pdf
Karl
yeh lovely mate thanks for that
spiky inbox :)
Karl
believe to hav found a live feed for my cc1 but the car wont start when its plugged in although the fuel pump primes i pluigged it into a 3 pin brown multiplug with a yellow wire connected to it (where cc1 is connected also) the other to have been cut off red and blue i believe is this right if not i cant find a switched live feed
stick some pictures up, do you have the crank sensor connected?
Karl
yes i do mate hold on i shall upload some photos thn youll se why im totally f****** confused :wacko:<_< where can i use to upload sthe photos
the internet!!!! :lol:
flickr, photobucket, imageshack, tinypic etc etc.
Karl
lol yeh just wanted a website haha never used 1 before ^_^ be 2 mins
Karl
a random unused plug dont know what goes here
wire 820 and 808 connected together with anothe unknown random wire dont know where this goes but guessing it goes somewhere as the stupid sparky has attatched a connecter on the end of them and cut it down to size for it to go somewhere
the white wire is cc1 and i have it plugged into what i believe to be a switched live feed as the pump primes when plugged in but it will not start
what my wiring looks like ..... shocking i know
as above ....
a couple of other wires not plugged in dnt know if there need or where they go
hope this helps anyone who can maybe make some sense of all this shambolic mess
EZ Tutty
Some of those connections are appauling! i'm not supprised your having problems, if your not confident with wiring i really would get it to someone who knows whats what and pay them to fix it, before you end up with a engine fire or something!
