205_sunderland
Building Bottom Arms With Rose Joints - If We All Chip In Money Saved
brumster
Absolutely; I totally understand what you're trying to achieve. I suggest you go for it, do it, and prove everyone wrong ;)
205_sunderland
A friend of mine makes these for a living as well as other "Motorsport" parts.......ie alloy hubs, perspex windows, Escort TCA's, Atlas Axle braces etc etc. With over 40 years experience as an MOD engineer he certainly knows what he's doing.
Do you think you friend would do you a drawing of the location bolt? and suggest his brand and size or rose joint , if he knows his stuff his knowledge will be a brilliant edition to this project :D
PS no-one has enlightened me how these bolts locate ok with there been a slot in the hub still ?
Edited by 205_sunderland
Rippthrough
the insert etc should be buttons to buy as arms arent exactly made out of hypermetapoly alloy themselves are they,
No, but then the stock arms don't have a high-strength joint threaded into them. Don't underestimate the preload you'll need to keep those joints tight...
205_sunderland
very true, thats why ill make sure i use a tried and tested size to allow enough tightening of them
205wrc
205WRC: How much are those?
I posted this last year. I'll double check the price with him tomorrow as it's a bit late to ring him tonight. He can either supply you with new arms.....or, modify your existing ones.
Like I said, give him a drawing and he'll make it for you! Jeff had a stand in the Race Retro show in Stonleigh, and also a stand in the Rally Day at Castle Combe.
I can guarantee his work 100% - he does all my personal machining work. He also makes components for West Wales Rally Spares and Historic Rally Sport etc.
He's in the process of making me some wheel studs - not the stud conversion type, but something similar to a Group 4 Escort type which screws through the hub and has a nut on the back of the hub t hold them. The back of the hub has to be machined flat to accept the nuts.
He's also making me a PTS spec rear brake conversion - we'll see how that turns out :)
http://forum.205gtidrivers.com/index.php?showtopic=118000&st=0&p=1063405&fromsearch=1entry1063405
205wrc
Have a look at my last post and click the link at the bottom
205_sunderland
thanks bud, do you think hed let the sizes for the pins slip? B)
Cameron
You can see the slot machined into the drop pin in 205wrc's post.
If you can't get a drawing I can knock one up for you (I did mention this before..) I'm an engineer at a large motor company y'see. ;)
205_sunderland
If you could get drawings itll be awsome bud, i dont have any spare parts at all, and working for a money grabbing bank call centre now so have no free time at all to measure parts etc so really appreciate the help
205wrc
You're lucky it's a dry night........Just been out measuring mine.
They are 16mm diameter (same as a standard ball joint), and roughly 85mm - 90mm long (shank length). The top shoulder of the pin is about 7mm thick, but ground down at a slight angle to clear the cv joint. M16 thread on the other end with a nyloc nut
wracing
Why use a rose joint at all, your target market is fast road, track use. Wouldn't a modified wishbone with increased camber designed to accept a replaceable BJ from an OEM application that was proven and truly fit for purpose be better.
If I'm not mistaken you don't really want to be adjusting camber angle on the rod end anyway. My reason for this is because bending moments conform to force multiplied by distance I'm sure ill be corrected if I'm wrong but this means the more you wind out the threads the bending moment increases rather quickly.
Personally I think you would be far better off to design a wishbone that offered a fixed level of camber addition that would accept a proven removable BJ fitted to thousands of cars. I spent some time designing my wishbones to accept the 306 ball joint with spherical bearing inners laser cut out of plate the bearings are held in CDS tube Tigged on to the plate. the thing that stopped me marketing these items was the liability issue, even selling kit parts not for road use still assumes some liability. My wishbones cost me no more than £100 for a pair. There is a thread on this but i will not post any drawings because that assumes liability but from the pictures i have posted im sure you could come up with your own design.
I understand your sentiment, i just don't think you understand the legal ramifications. They stopped me i wish you better luck
James
Edited by wracing
SurGie
The shanks on mine are 100mm in length and the overall size is bigger, weights about 1kg in total.
There is "FCURO" printed on it.
205wrc
Your hubs must have been re-drilled then to accomodate the larger diameter pin.
205_sunderland
James
How does it make you liable making a drawing mate? if you have no physical part in making them its got nothing to do with you at all ? this seems like a bit of the old american where theres blame theres a claim bulls*it polluting our none retarded world once again...correct me if im wrong?
SurGie
The hub shank not thread shank is the same 16mm.
wracing
Unfortunately I can't correct you but it is how it is in the western world.
If you killed 10 people on a motorway I'm sure you employ a solicitor to defend you, a credible defence is that what you have already admitted you don't understand the field and you quite simply replicated what you thought was a credible design, thus liability is not of your own but that of the designer.
It is how it is at the moment which is why there is a large mark-up from these Motorsport companies not only to pay the wages but to pay the insurance.
I wish it wasn't like this.
James
205_sunderland
James
thats disgusting, ill not post the drawings, i make it the case they will only be availiable on request to who i trust fit, problem solved, i trust people on here...plus ill get your address before you get the drawings so i know where you live,
i have done kick boxing,jui jitsu,normal boxing and wrestling as part of the mma training ive done over the years so you have been warned :lol: :lol: :lol: :lol:
Flozman
Just spent a good 45 minutes catching up on this thread, My feelings toward Motorsport companies has always been the same, id rather make up my own mind regarding the methods they use. Some parts are priced with a little scene tax, the better your reputation is the more money you can charge because people like to have well known brands on cars as well as their clothes. Yes I also know the overheads are crazy, this is Britain after all!!!
But when it we are talking Motorsport spec ball joints, they simply cannot afford to piss arse about they have to be over engineered to such a degree that they might be ten times stronger than any force they are ever likely to encounter. One single failure and its shut up shop time.
Okay now having said that all I want is a ball joint that lasts much longer and can handle the pot holes on the way to work. Can this be done or do we always have to go rally grade?
Floz
205_sunderland
This is the sizes i need and for the sake of the terrible americanised world we live in now which makes me sick, just fill it out and send it to me via pm, and suggestions on material to use?
and i did the drawing on paint so dont be blown away :lol:
My dims, use at your own risk, these suit my application and needs only.
Plain shank length 55mm
Thread length 20mm
Thread form M16x2
Head length 4mm
Head dia 24mm with flat to core dia one side
Shank diameter 15.98-16.00mm
Notch dims no info as I will machine in situ.
Cameron
That's not bad for MS Paint - boy got skills. :lol:
I'll try and knock up a proper drawing tonight for you, handily I have a 205 in pieces so it should be pretty easy to measure everything.
205_sunderland
cheers bud just let me know when you got the sizes im still waiting back on prices for aurora joints yet
205wrc
Here you go.......
This is the chap I was on about
http://jsmotorsport-machining.co.uk/
This is only a small example of his work - contact him direct for prices etc.
205_sunderland
Here you go.......
i highly doubt hell give me the drawings though if i ring up and ask :lol:
205wrc
Hmmmmmm.........NO :D
But he'll sell you a pair of Rose Joints.......or even a pair of arms.
