Ant 2 Posted November 8, 2008 Folks, ive taken apart the oil pump this morning on my 2.0 turbo and removed the pump part with the mess inside from the rest of the pump ( the 6 bolts ) Inside there was a spring which i removed. It was only when i came to fit it back together i noticed there is a small bolt / rivetty thingy sitting inside the sping. Which side does this go on. The part i removed, or the chain side of the pump ? Thanks Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted November 8, 2008 Small bolt rivettey thing?! Can't think what it could be, have you a pic? Share this post Link to post Share on other sites
Ant 2 Posted November 12, 2008 This is the pin thingy. Any info on which side this sits ? Cheers Share this post Link to post Share on other sites
Ant 2 Posted November 14, 2008 Anyone ? I'll like to start putting this back together tomorrow Cheers Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted November 14, 2008 I've taken 2 oil pumps apart recently and not seen one of those, can only think it sits inside the spring at the opposite end from the relief valve to support it somehow. Share this post Link to post Share on other sites
Ryan 99 Posted November 14, 2008 It goes on the opposite end of the spring to the piston. They're only fitted to some pumps and not others. No idea why... Share this post Link to post Share on other sites
Ant 2 Posted November 15, 2008 Ryan, not sure what you meen when you say piston.. Is it the side that doesnt detach ( ie the side attached to the oil pump chain ) or the small side i have removed that contains the metal filter gause / Cheers Share this post Link to post Share on other sites
