marksorrento205
309 Gti Rear Beam Tube
SurGie
So are the torsion/anti roll bars avalible from pug as well ?
How much are they ?
It all good part from the seals, are they getting you some as a good will gesture ?
I think it should all be included.
i think it should all be alot cheaper, but i also think i should win the lottery... :wacko:
marksorrento205
They have done me good, other bits and bobs ie bolts and washers that only come in bags of ten they have thrown in:rolleyes: If you want any of these for your rebuild let me know and you can have them for postage costs. The torsion bars I have gone for are the partner ones as one of the 309 ones is no longer available and I think they were abougt £120 for a pair. The seals are only 4 quid or so. Gonna source a gti6 ARB from some where next.
marksorrento205
I second that :)
jord294
from experience, i rebuilt a 309 beam, and the only parts that weren't new, were the tbs, arb and trailing arms
so in all, it owed me about £650
sold for £375 :wacko::)
marksorrento205
sold for £375 :);)
After I have rebuilt this one someone would have to chop my arm off to get hold of it coz I aint letting it go :wacko: Crazy prices but saves me from decorating the house!!
SurGie
Yeh sure, thanks for that and the info on it all !
Will the partner torsion bars need to be made smaller or is it a straight fit ?
Also will the gti6 ARB fit straight in as well ?
Send us your payment details via PM for postage & cost, ie paypal.
Cheers Marksorrento205
marksorrento205
There is a thread about 21.3 mm torsion bars in this section. According to that they fit no mods and they have the part no which is what I ordered. Same for the gti6 ARB I think but would like some one to confirm for my purchase!! ( Baz, anthony :ph34r: ) Will sort PM out in the next few days and post pt no etc.
Alastairh
306 ARB won't fit without modification.
marksorrento205
What mod's or alternate ARB do you require/ can you use?
marksorrento205
No they are too long as standard. All i did with mine was chop it down and weld one of the end plates on. Obviously when you do this you need to ensure the other endplate is fitted and both are flat and level, as you have no adjustment when you put it in the beam. You could get it resplined, but to me this was alot of hassle and money for a part i paid a tenner for, and ive had no problems so far with the welded one.
The answer
jonnie205
yeah that swhat i did was weld the end plate on, cut to the right length then i also ground the bar small enought to fit inside the old splined section of end plate. I then plug welded the bar to the end plate and mig welded all round the outer lip too. You will need to turn the wleder right up to get the propper penetraition into the bar and make sure its totally square before weldin
marksorrento205
cheers jonnie!!
Or just have one re-splined. :D
Tesstuff
Oh damn Mark, that reply could be rather costly :D:D;)
marksorrento205
For info, how do you have that done? Rough price? and the biggest question who does it?
Thanks Baz
Through 205Parts.
marksorrento205
Will bell them for a quote cheers
marksorrento205
SurGie
For your info some part no's
309 crossmember 514849 x1
Crossmember end seal 515408 x2
Cup that goes over seal before trailing arm is fitted 515409 x2
Trailing arm shaft 517617 x2
13mm nut 693238 x2
stud that screws into torsion bar small end 515310 x2 these are on backorder at my pug until end of nov - may have 2 extra I think they ordered 4
Washers for above stud under 13mm nut 6962.66 x2 Got a bag of 20 of these if you want a couple
Offset washer 515312 x2 Got a bag of 10 of these if you want a couple
Screws for above 515311 x2 " " "
Plastic caps in end of ARB end plate 515408 x2
ARB end plate seal 517910 x2
Partner 21.3mm torsion bars 515063 x1
515066 x1
The ones in blue are what I have extras of that you can have for the price of postage - pm me.
Tesstuff
Mark, you are aware that as i fetched your tailgate for you and this weekend im fetching your bonnet for you, you have infact made up MY new rear beam for me :o
It's only fair fella :wacko:
p.s Never forget , it's far better to give than receive B)
p.p.s Dont worry, the next beam can be for you :o
Edited by Tesstuff
marksorrento205
:) :) B)
We shall chat when I pick my bonnet up :)
