Guest rhombus
Cti Starting Problems
Guest rhombus
I have a 1.9 205 CTi with an irritating intermediate starting problem. About one time in twenty the car will not start but the starter turns the engine over.
I have put a spark plug tester between the lead and the end plug and the little neon light does not come on.
If I then take out the end spark plug and turn it over on the starter it then starts on three cylinders , or at least shows signs of firing.
If I screw the plug back in and reconnect the lead it starts up fine.
Any suggestions about what the problem is or what should I replace first?
Henry Yorke
Could be ignition amplifier, dodgy HT leads, lose wire. Check the wires from the coil first and do some wiggle testing before buying anything
Guest ryan_NIGTI
ignition module maybe? coil?
large
Dizzy cap,rota arm and leads. Check the earthing point on the gear box.
