SPGTi 2 Posted September 20, 2008 I have picked up the coil pack from a 406 2.0 16v with "intergrated leads" to fit onto a GTi-6 head to replace the individual coils. Anyone know what the the pins 1-4 relate to as the 3 wires are all yellow. So which number is live and which cyl do the other 2 relate to ? cheers Steve Share this post Link to post Share on other sites
Richie-Van-GTi 83 2 Cars Posted September 20, 2008 (edited) pin 1 = pin 1 ECU pin 2 = pin 19 ECU pin 3 = switched live pin 4 = earth via a suppressor You'll need to research this quite well as your coils will be earth triggers for each coil (sequential) via the ecu but the coil you have is only semi sequential (wasted spark). Also it is earth triggered but the dwell of the coils may be diferent. Edited September 20, 2008 by Richie-Van-GTi Share this post Link to post Share on other sites
SPGTi 2 Posted September 20, 2008 It will be running DTA not the std ecu so should be fine in that respect. The problem at the moment is getting it to fit. cheers Steve Share this post Link to post Share on other sites
