Spiky
What Platform Front Suspension For 400-500?
check the bonnet pin in the background on the lip of the bulkhead, bad Idea IMO and will look gash!
Edited by welshpug
Spiky
ah you mean it's raised heavily?
yeah, i'm not really liking that idea to be honest :(
Martin W
I raised the bonnet pins on the back, but with a very thin carbon bonnet I had to put a 5th bonnet pin on the front of the bonnet to stop it flapping. It looks ok and there is no need for a 6th bonnet pinon the bulkhead.
oli-pug
I quite fancy getting a pair of gaz gold fronts now actually.
I should be a able to get a very good price through my work as we fit a lot of gaz and nitron kits to the tvrs and lotus'. I'm sure i could sort something out if anybody's interested in a set.
Bally
I do not run the bonnet raised at all. I run just a fibreglass skin so I use bonnet pins to secure it.
I have had two reverse scoops installed to clear the raised towers.
Look at the pics and you will see the reverse scoops
Spiky
ah cool, so will remove hot air too ^_^
any pics from the front angle? :)
TVH
yeah they looks nice, can you measure the bodies?
325, mine are 300, and fine them fine ^_^ but i'm running std 309 rear ARB
Sorry the car is 100km from home...I will measure once I get it back to my own garage!
Bally
More pics in my project section. My Project
Alan_M
I'd be interested in front struts only ^_^
tom_m
bit delayed, but the bodies on my bilsteins are 330mm top to toe, can't really say what the damper travel/sag is yet because there is no engine in it at the moment.
cybernck
i was just thinking about what happens when the eccentric top mounts are fitted
above the strut tops prior to seeing this topic and i figured out that in this case
it's just the mounting bolts taking up all the load, while when they're mounted
below (like they should) it's the whole top mount that takes the load.
btw, another round of GAZ group buy deal is currently under way :rolleyes:.
