TaffyTim
Alternator Wiring
TaffyTim
I have just put a 2nd hand alternator on the car and Just started it up and it threw out loads of smoke :)
Have i wired it up wrongly? I put the spade connector on the spade and i thought i put the other wire on the negative, is this wrong?
Yes thats wrong, nothing goes to negative, it grounds through the body.
TaffyTim
Colour blind people should not be allowed to play with electrics :)
This might be a stupid question but why is there a negative terminal on it if its not used? I presume its not just there for an armature pyrotechnic show?
Rippthrough
Should be one wire to the dash warning light, one wire to the 12v distribution block, and one big fat 12v wire to the battery.
205's don't have the wire from the 12v distribution block, at least not on any I've seen or had.
Graham.
Rippthrough
Graham.
Pass, haven't got one, but it still shows there shouldn't be one to earth :)
