TaffyTim 6 Posted June 17, 2008 (edited) Ive had all 4 wheels reconditioned. After having the tyres fitted I can not get the 2 offside wheels off (to be swapped for my wheels with R888's). The wheels are stuck fast ans no amount of pulling at them is having any effect. Ive even taken the bolts off the rear and slowly dropped it back to the ground, the wheels take the weight of the car without the bolts!!! Suggestions please. Edited June 17, 2008 by TaffyTim Share this post Link to post Share on other sites
welshpug 1,737 Posted June 17, 2008 (edited) you need a rubber mallet or a lump hammer and a piece of wood, I guess there was no anti-seize between the disc and the wheel. other option of to fit 4 bolts, and ever so slightly loose, drive round in circles slowly with someone watching each particular wheel till they come loose, they will usually clonk and move visibly when they loosen, done this on an 18t Scania and a renault premium!! Edited June 17, 2008 by welshpug Share this post Link to post Share on other sites
TaffyTim 6 Posted June 17, 2008 no grease put on by the monkeys that swapped my wheels over But they did swap 8 wheels/tyres for £40. The drivnig with loose bolts sounds a good idea. I had thought about it bu didnt think it was too safe. Share this post Link to post Share on other sites
welshpug 1,737 Posted June 17, 2008 just don't go too far! all you need is enough space to turn a 205 round on full lock, as soon as a wheel loosens whip it off clean it up with emery paper or suchlike, bit of anti seize and jobs a goodun Share this post Link to post Share on other sites
Jrod 7 Posted June 17, 2008 Or just stop being a big girl and give it a kick. Share this post Link to post Share on other sites
MerlinGTI 3 Posted June 18, 2008 Or just stop being a big girl and give it a kick. uh hu! put the bolts in a few turns only, the kick the tyre whilst sitting down, rotate and do again although the tyre monkeys probally didnt help matters, your probally find it was actually the refurb thats caused this! (thicker paint on the inside of the wheel where it fits over the hub) Share this post Link to post Share on other sites
timmsy19 3 Posted June 18, 2008 Or just stop being a big girl and give it a kick. yep was going to say this.... had the same trouble with mine so pondered about it for days then just got annoied and kicked it to which it just fell off Share this post Link to post Share on other sites
daza4 24 Posted June 18, 2008 Yep give it a kick or a scaffold plank used as a lever bar whilts rotating the wheel will pull if off eventually. Share this post Link to post Share on other sites
TaffyTim 6 Posted June 18, 2008 Oh i hadnt thought about kicking it................................................. please............................... before posting this topic I had kicked the thing so hard its almost fell off the jack. Give me some credit!! Im going to have another pop at it tonight, I'll fill the tank up with fuel and my jerry cans and keep them on board to give it a bit more weight. Heres hoping. Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted June 18, 2008 (edited) sledge hammer and a bit of wood?? Edited June 18, 2008 by johnnyboy666 Share this post Link to post Share on other sites
Paintguy 0 Posted June 18, 2008 The front will be easy, especially if you have PAS. Wheels off the ground, one bolt on a few turns to stop the wheel falling fully off. Turn steering to full lock one way, wedge a peice of wood betwen the wheel and the chassis/subframe, then turn the steering wheel against it. You get loads of extra leverage from the steering, so it'll pop right off Share this post Link to post Share on other sites
TaffyTim 6 Posted June 18, 2008 I did the driving with loose nuts trick today. The front wheel came loose and is now fine. The rear would not budge. I drove forwards and backwards in circles and in sharp turns. Its still stuck fast. The wood and heavy hammer approach sounds fun but i think i will knock the car off its jack. Is there a way of doing it that im not thinking about? Share this post Link to post Share on other sites
welshpug 1,737 Posted June 18, 2008 the car should be on an axle stand mate Share this post Link to post Share on other sites
TaffyTim 6 Posted June 18, 2008 lol, ok i dont deserve any credit. Of course it should will that be enough to hold it? Share this post Link to post Share on other sites
welshpug 1,737 Posted June 18, 2008 should be, if you have any spare wheels place them under the sill to prevent it from falling to the ground were it to come off the stand. piece of 4x2 and a lump hammer on the inside, a few firm blows at 180 degrees should do the trick (put it in gear with the wheels chocked but handbrake off) Share this post Link to post Share on other sites
johnnyboy666 195 1 Cars Posted June 19, 2008 or a few handbrake turns in the required direction with loose bolts?? (on a serious note, dont try this lol) Share this post Link to post Share on other sites
TaffyTim 6 Posted June 19, 2008 tyre monkeys got out their rubber mallet and after 10 mins of whacking it off it came. Share this post Link to post Share on other sites
