Atari Boy 11 Posted April 17, 2008 I am thinking of getting an aftermarket ‘Tim’ gauge or two and can’t decided there to put them. I would like the car to look at ‘OE’ as possible so have discount A pillar pods and dash mounted things. As I see it, I can lose the stereo and fit them there but is there anywhere else that works and looks quite stealth? Photos of would be appreciated. Thanks Jonny Share this post Link to post Share on other sites
sonofsam 5 Posted April 17, 2008 You could hide a couple of pods by the side of the steering column plastics where it meets the centre console? Or the center console itself, infront of the gearstick where that little tray is? Share this post Link to post Share on other sites
Ryan 99 Posted April 17, 2008 I wouldn't buy Tim gauges. They're about as accurate as the standard gauges. My local Halfords has Tim gauges on the self next to all the chav crap, and the boost gauges don't even read zero when set unconnected in the box. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted April 17, 2008 Agree with the above. Racetech gauges are good and not that expensive. Share this post Link to post Share on other sites
Atari Boy 11 Posted April 17, 2008 Okay, plan B Racetech then. Share this post Link to post Share on other sites
MrG 3 Posted April 17, 2008 I may do this with the oil pressure gauge so I'll jump in here. Can the original oil gauge be substituted within the dash for an aftermarket item? Share this post Link to post Share on other sites
sonofsam 5 Posted April 17, 2008 I may do this with the oil pressure gauge so I'll jump in here. Can the original oil gauge be substituted within the dash for an aftermarket item? Yes! I did this for my boost gauge install. Share this post Link to post Share on other sites
MrG 3 Posted April 17, 2008 many thanks, something else to add to the list! Share this post Link to post Share on other sites
swordfish210 20 Posted April 20, 2008 First i will say if you're going to buy Racetech guages just buy Mocal guages instred. Exactly the same guage, it just doesnt have "Racetech" printed on it and they're normally about 20% cheaper than racetech ones. Secondly i mounted my oil pressure/oil temperature and fuel pressure guage here: Share this post Link to post Share on other sites
Atari Boy 11 Posted April 20, 2008 Sonofsam's dash efforts looks wicked but probably above my skill level, Swordfish's idea is great, and one I hadn't thought of, thank you. Share this post Link to post Share on other sites
GLPoomobile 958 Posted April 20, 2008 No offense to Swordfish, but if you are going to mount gauges down there, where they aren't in your immediate vision, you may just as well stick them in the little coin tray in front of the gearshift. I'm sure they fit as I've seen them there before, they would be far easier to fit in that piece of trim (I'm reckoning) and the piece is far more easily replaceable if you decide to return it to standard than that flap would be. Also, are TIM gauges really that bad? It's the first I've heard. I posted a topic last year asking for suggestions on gauges and nobody said anything bad about them then! Consequently I bought TIM oil pressure and voltmeter gauges (still to fit) as they were reasonably priced and TIM is a name I know has been around for years, and not something I consider synonymous with the gay 'modified' scene (poor quality gauges with glow in the dark backlighting and LEDs etc). If they are that bad then I'll eBay them and get something else. Share this post Link to post Share on other sites
engine killer 6 Posted April 21, 2008 has anyone tried fitting a guage/gauages in ash-tray and/or digital clock? Share this post Link to post Share on other sites
tom_m 0 Posted April 21, 2008 (edited) i made this: but i've yet to use it in anger. Edited April 21, 2008 by tom_m Share this post Link to post Share on other sites
swordfish210 20 Posted April 21, 2008 No offense to Swordfish, but if you are going to mount gauges down there, where they aren't in your immediate vision, you may just as well stick them in the little coin tray in front of the gearshift. I'm sure they fit as I've seen them there before, they would be far easier to fit in that piece of trim (I'm reckoning) and the piece is far more easily replaceable if you decide to return it to standard than that flap would be. Yes that would have been easier if i was using electrical guages but i'm using mechanical ones and they have a lot of gubbins on them as well as the light bulb that just wouldnt have fitted under there. It was one of my initial thoughts but it wasn't hard to fit them in that flap and now all of the pipe that comes with it is tucked away behind there in the cubby space Share this post Link to post Share on other sites
tri_longer 25 Posted April 21, 2008 At least you have that flap to mod, i've got a bloody cassette holder!!! I'm looking at making a carbon fibre plate to fit the gap and then fit the gauges in there the same as yours. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted April 21, 2008 Gauges mounted down there are not good IMO, they need to be somewhere you can glance at them without looking majorly away from the road ahead. Share this post Link to post Share on other sites
sonofsam 5 Posted April 21, 2008 has anyone tried fitting a guage/gauages in ash-tray and/or digital clock? I did have a look at fitting one there, even found a blanking plate from a base model in the breakers, figured the ashtray would be kind of difficult to cut a nice hole because of the pull down flap on the front of it?! Share this post Link to post Share on other sites
GLPoomobile 958 Posted April 21, 2008 I've toyed with the idea but I'm put off by cutting away at the dash behind the ashtray and clock. When I eventually get around to it I'll be modifying the air vents or making a housing to go where the top coin tray sits. Those bits are easily replaceable. Share this post Link to post Share on other sites
bobob 0 Posted April 21, 2008 Sorry to hijack, but what do people think of Smiths gauges? Share this post Link to post Share on other sites
oli-pug 6 2 Cars Posted April 21, 2008 Smiths gauges are pretty good mate, and look nice and subtle too! I fit them regularly in the elise 1.8t conversions at work. Its either them or spa design if the customers got a good budget, they are gauge porn! I'm personally going to make a blanking plate for the coin tray (it's bust anyway!) then fit a gauge pod on top. Although ideally i would modify the standard clocks to house a big tacho, shift light and and decent oil pressure/temp gauges. Share this post Link to post Share on other sites
Craigb 2 Posted April 21, 2008 Gauges mounted down there are not good IMO, they need to be somewhere you can glance at them without looking majorly away from the road ahead. possibly Tom if fitted in isolation , if using a warning light as well , the gauge position is not as important as the warning light alerts your attention before having to look at the gauge Share this post Link to post Share on other sites
