Mac210882
Anyone Got A Guide To Getting To The Heater Matrix?
Mac210882
Howdy All
I've tried to use the search function for 'heater matrix', 'matrix', 'coolant leak' etc but I seem to get a variety of unhelpful results. I'm after a guide at getting to, and replacing the heater matrix pipes. I seem to have a problem with one or more of the pipes in the dash, as my footwells are soaking wet after a run. It's only just started happening after it's last outing and hasn't been driven since.
I've been upside down with a spotlamp in the footwells and there doesn't seem to be any easy way at getting at the plumbing, I can't even see where the leak is coming from. In the Haynes manual it's a 4-spanner job, but it doesn't really give you a good guide to actually get under there and get to the pipes
Just a few questions:
1 - is this a common problem on 205's?
2 - how do i get to the heater matrix and pipes, is there a guide anywhere?
3 - does anyone have a diagram showing what does where, like an exploded heater matrix image?
Iain
EDIT - I found this, which is quite helpful, but I could do with some pics if possible?
http://forum.205gtidrivers.com/index.php?s...0&hl=matrix
Edited by Mac210882
Alastairh
1 - is this a common problem on 205's? Certinly not unheard of.
Drain the cooling system, Remove the 2 rear coolant pipes that go into the bulkhead. Then in side of the car, remove the plastics below the steering colum. Removing the stereo and centre console may help, and also means if your stereo hasn't already died, its less likely to die not being there. Then look for the 2 metal pipes up behind the dash. These go into the heater box. the matrix should be held in with 2 bolts, slide it out, replace all pipes, seals and the unit itself which are around £20-£30 from GSF.
I don't, but its dead easy once you've got the part in your hand and start taking the car apart. The last matrix i done took sub an hour :)
Al
M_R_205
Is it definatley the matrix? i used to get wet foot wells in my old car when my door seals were gone, also head of problems with sun roofs and condensation.... just a thought
suth82
Check that the drain points under the sills are not blocked, this is the most common cause of water in the footwells, there is a rubber gromit on the sill near the rear arch, stick your finger up it and see if water comes out.
You should be able to tell the difference between coolant water and sill water by the smell alone, failing that a quick touch and taste!!
Paul
Mac210882
Thanks guys - definitely coolant as it's lovely and warm, and is flourescent green :unsure:
Alistair - will give that a go, cheers bud
Iain
