sutol
Front Arb Bushes Sizes
sutol
You wont believe the trouble I've had getting front ARB bushes to fit My 1.9 GTI
I measured them at 17mm but the motor factor keeps coming back with 20mm bushes and insists they are right.
I've measured the diesel TD bar and that is also 17mm as is the Gentry which is supposidly 1.6 GTI
Have I got an odd bar or are the motor factors wrong??
brianthemagical
are they 20mm compressed?
GLPoomobile
From Servicebox:
Except GTI, Except Ralleye, Except Turbo Diesel:
5094 36 - Diam 20
5094 37- Diam 22
5094 40 - 1 pos diam 23
GTI and Ralleye and Turbo Diesel:
5094 42 - left
5094 43 - right
So basically, the above seems to confirm that the GTI uses the same bushes as the Ralleye and DT only, and that others are 20 or 22mm. You also have to remember that the GTI uses to different bushes as there is a locating bulge for one side.
I'd just forget the factors and go straight to pug. They are only £4 and a bit each from them.
Edited by GLPoomobile
sutol
Cheers for that,
I measured the bar thicknesses of a 1.9 a 1.8TD and a Gentry and they are all 17 mm.
The hole in the bushes that came off the 1.9 is 17mm so those three models are all the same
