Roman 0 Posted February 11, 2008 hi! I have strange problem with 1.9(motronic1.3)DKZ engine.When i start car(cold in the morning) K-light blink 3time and then light stay on,but if i turn off ignition and start again this odd think disapeer .Car runing normal and K-light no pop again.But after 3-4h(car not running) same problem again i search in old post but i dont find something like these Share this post Link to post Share on other sites
Powers 13 Posted February 11, 2008 It might be worth changing the ECU temperature sensor. Share this post Link to post Share on other sites
Roman 0 Posted February 11, 2008 It might be worth changing the ECU temperature sensor. it's new -new lambda and car run sweet... Share this post Link to post Share on other sites
Roman 0 Posted February 11, 2008 it's new -new lambda and car run sweet... anibody????? Share this post Link to post Share on other sites
cybernck 428 1 Cars Posted February 11, 2008 you need to read out the error code it gives you and then you'll probably find out what's wrong with it . Share this post Link to post Share on other sites
1 FAT PUG 39 Posted February 12, 2008 try just disconnecting the battery for a couple of hours as the ecu might need to reset itsself Share this post Link to post Share on other sites
Roman 0 Posted February 12, 2008 try just disconnecting the battery for a couple of hours as the ecu might need to reset itsself i try this first-but still no luck Share this post Link to post Share on other sites
Roman 0 Posted February 12, 2008 you need to read out the error code it gives you and then you'll probably find out what's wrong with it . i know this but dont have tester.... Share this post Link to post Share on other sites
Rob Turbo 3 Posted February 12, 2008 It can be done with a bit of wire, do a search for motronic fault code read or something and it will show you how, basically you put a wire into the diagnostic plug then put the ignition on and earth the wire then the k light will flash the code out Share this post Link to post Share on other sites
DamirGTI 366 Posted February 12, 2008 (edited) Hello ! Yes it can be done on DIY basis , just need to learn how to count bulb flashes .. You can download Haynes Diagnostic book form here : http://forum.205gtidrivers.com/index.php?s...ynes+diagnostic (inside you'll find self diagnose procedure explanation for all sorts of car brands and engine management types , the Motronic system and 205 GTi fault codes are also included ) Have fun ! Damir Edited February 12, 2008 by DamirGTI Share this post Link to post Share on other sites
Roman 0 Posted February 13, 2008 Hello ! Yes it can be done on DIY basis , just need to learn how to count bulb flashes .. You can download Haynes Diagnostic book form here : http://forum.205gtidrivers.com/index.php?s...ynes+diagnostic (inside you'll find self diagnose procedure explanation for all sorts of car brands and engine management types , the Motronic system and 205 GTi fault codes are also included ) Have fun ! Damir thanks Share this post Link to post Share on other sites
Roman 0 Posted February 16, 2008 thanks I solve the problem with you help-of course change ECU change lambda(again) and reset ECU now work fine thanks again.. Share this post Link to post Share on other sites
cybernck 428 1 Cars Posted February 16, 2008 cool... but have you tried the original ECU now you've sorted it out, to check if the ECU was the fault? Share this post Link to post Share on other sites
petert 641 Posted February 16, 2008 For future reference, the procedure can be found here: http://www.aussiefrogs.com/forum/showthread.php?t=24847 Share this post Link to post Share on other sites
Roman 0 Posted February 17, 2008 cool... but have you tried the original ECU now you've sorted it out, to check if the ECU was the fault? yes i try... ECU is vorking normal(old one) no erorr code's but still light comes sometime i check with 3spare and all ok Share this post Link to post Share on other sites
cybernck 428 1 Cars Posted February 17, 2008 oh well, maybe someone has "chipped" it in the past and eprom checksum is not 100% right. that's unless it started showing error coded only recently which would mean it's simply buggered . Share this post Link to post Share on other sites
