matt-k 0 Posted January 13, 2008 As title thanks. Just trying to start it for the first time and want to check ive got it right. Cheers Matt Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted January 13, 2008 As title thanks. Just trying to start it for the first time and want to check ive got it right. Cheers Matt 1-3-4-2. Share this post Link to post Share on other sites
Ryan 99 Posted January 13, 2008 (edited) #1 is at the flywheel end btw. ...Got caught out by that once. Edited January 13, 2008 by Ryan Share this post Link to post Share on other sites
cybernck 428 1 Cars Posted January 13, 2008 that goes for any modern 4-cylinder "otto" (internal combustion) engine, doesn't it? Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted January 13, 2008 that goes for any modern 4-cylinder "otto" (internal combustion) engine, doesn't it? not always, some are 1-3-2-4. Share this post Link to post Share on other sites
boldy205 75 Posted January 13, 2008 Think alfas are differant, but then you need to worry more about the things catching fire than the firing order of the engine!! Share this post Link to post Share on other sites
matt-k 0 Posted January 13, 2008 #1 is at the flywheel end btw. ...Got caught out by that once. 4 3 2 1 0-0-0-0 Chambers 1-3-4-2 Firing order So, if i number my chambers as above with number one on the flywheel side it will fire number 4 first then 1 then 3 then 2. Correct? Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted January 13, 2008 (edited) 4 3 2 1 0-0-0-0 Chambers 1-3-4-2 Firing order So, if i number my chambers as above with number one on the flywheel side it will fire number 4 first then 1 then 3 then 2. Correct? no, number 1, flywheel end fires first. Edited January 13, 2008 by pugger Share this post Link to post Share on other sites
