r.u.sure
205 Gti-6
Spiky
will do guys, will fit to the car before i rip it apart :wacko:
Spiky
well it was delivered today :wacko:
just fitted it,
and it's works a treat
only issue i have is that my welded one is 56.88mm think, where as this one is 50.00mm thick,
so to test i put some washer on top and started it up, and it's much better :lol:
well please with that, especially as it only cost 14quid delivered, and if it fails in 6mths it's a cheap replacement
OR
or get this, which will again need spacer's but will be hard and last longer
http://www.vibra-technics.co.uk/parts/part...ails.asp?id=306
All Praise The GTI
so how much has it actually lowered the engine by spiky? and have you lowered the box to suit?
iam stil thinking about how to do mine but dont want to have driveshaft issues as having 309 items they cost abit!
Spiky
give me 5 and i'll go measure and take some pics
i have lowered the gearbox down some mm not as much as the drivers side though,
i'm running 309 wishbones and shafts, as long as you dont extend the bottom rear mount more than 10mm, the shafts will be fine (i'm speaking from trial and error)
Spiky
ok
BBM mount is 74.56 mm thick
my welded one is 54.5
mk2 rs2000 is 50mm (buy i made it 54 with some washers)
hope that helps :wacko:
Edited by Spiky
All Praise The GTI
excellent. great find thanks mate
ill be ordering one of them then!
James_m
Good find! What are peoples opinions on running this mount with a standard lower and gearbox mounts? Would i get driveshaft issues?
Spiky
why would you?
its a ver hard rubber used on the mount, same as the BBM one i have, it may even be a bit harder
James_m
Because my cam covers rubs on the M/C so i thought it might be an easy fix. I dont really have any other clearance issues other than that so i have no need to drop the entire engine/box. But thinking about it the angle would throw off the lower mount fitment so i cant see it would work anyway
r.u.sure
Good find Spiky thanks very much for that, will be ordering one up soon, might even go for the uprated one.
Quick question though, how do you lower the gearbox side down, is it just a case of putting washers on top of the mount ?
Magic, thanks very much for the reply, think I'll try one of these first, no offence.
Thanks again for all the replies on this.
Dave
Spiky
yeah, used washers :)
r.u.sure
Nice one, thanks again :)
