Spiky
Bilstein Suspenion
Spiky
ok i plan to run proper bilstein suspension now,
i can get hold of the casings for 95 each,
but wheres the best/cheapest place to purchase the inserts?
what would be ideal ratings? 300/200????????
what poundage springs shall i get?????
what length springs?
Chris H
As your in Cardiff i'd suggest poping down to peter lloyd rallying in Bridgend...they will be able to sort you out.
Jrod
I got mine from SBC.
Spiky
sorry, whats their full name? have they a website?
edited to add
it's ok worked it out now, skip brown cars :)
will look on PLR website now, :mellow:
Edited by Spiky
Spiky
PLR are 139 each :)
Batfink
have you got part numbers? Drop me a pm as I may be able to help :)
Edited by Batfink
Spiky
i dont B)
already been asked that ... :)
will try and find out :)
Don;t forget the front inserts usse both long and short top threaded parts for Rose Jointed and std top mounts
Spiky
from this post the part number is part no F4-V36-0547-HO
http://forum.205gtidrivers.com/index.php?s...amp;hl=bilstein
MILES
i need the long as i will be going to use eccentric top mounts, but not straight away, so for the time being will be using std top mounts and using a sleeve for the time being.
Spiky
in fact these are the front and rear shocks i want
just need to find the cheapest place :)
front
http://www.specialtuninguk.co.uk/acatalog/...op_Spindle.html
rear
http://www.specialtuninguk.co.uk/acatalog/...309_Gravel.html
after searching
I know allot of people run the Group 'N' or otherwise known as the challenge spec items are
Front; Group 'N' Front Bilstein strut's F4-V36-0547-H0
Rear; Group 'N' dampers F4-B46-1038-H0
The front's use the std dia spring which can be anything from Eibach to Gmax
Edited by Spiky
Matt Holley
I want to change to these shocks, just trying to justify more money spent on the 205 at the moment though :)
Would the fronts work o.k with koni rear shocks for now? I am using a 309 rear beam and will be using 309 shafts and bones btw
Edited by matt holley
Spiky
ive been told i "should" match them
Matt Holley
Thats o.k I have all winter to save the pennies :)
Let me know what you think of them when you get yours :)
Spiky
you can take it for a drive dude, we basically got the same car...lol
Basically now Bilstein only supply one rear damper, the 1038's which cover both 205, 309 & 306, Not sure what special tuning etc supply now but I bet it's the same one listed for Greval or Tarmac.
I can;t remember which of the front insert's are stocked by Bilstein now, as I know one of them needed a min order of about 50 unit's.
Another option but more expensive is the AST's, these have been developed in the last few yr's compared to the billies and as everything, thing's progress
Jrod
Miles, do you know anything about the 1039's as my mate was sold these as group N which theyare not and they seem really soft. Any idea what they are. :)
Jrod
Cheers,
Explains why his part numbers don't match mine, fronts aswell he has just sport shocks rather than group N.
He got them from demon thieves aswell...
Edited by Jrod
the 1039's are listed as B6's (Off road),
I;ve got a hole load ofObsoleted stuff in the Bilstein book
Jrod
Could you tell me what F4-V36-0545-H0 are listed for please? :wub:
Edited by Jrod
These are listed as 205 1.0 > 1.9GTi's and derv's B6 Front Dampers along with the 309 GTi, which we know is wrong as the damper's don;t really fit the base models
Spiky
these price's look ok to you guys????
SPGTi
The insert seems a bit expensive. The "normal" price is / was £121. Are the springs the PTS 70mm (I think) size ? If yes, it might be worthwhile changing to 2 1/4" as the springs are more readily available and are around £20 each. This would mean using different tophats and lower spring pan though.
Go to Peter Lloyds in Bridgend he has most of what you need on the shelf and his prices are usually v. competitive. Also look at www.compbrake.co.uk for prices on new strut cases and other hardware.
Steve
Spiky
sorry , forgot to add
the insert is from PLR
the casing and top mounts is from COMP BRAKE
the springs from SPECIAL TUNING
