john-melbourne
Problems With Electrics
Its a 1988 Phase 1 i believe, the reverse lights are part of the rear cluster.
Ok, that means its unlikely to be a corroded plug as I mentioned in my last reply.
I've merged both of the topics you had running for the same problems into this one.
Graham.
john-melbourne
You do have a bulb and a bit of wire though :(
Forgive my stupidity, but do you get two pieces of wire one either side of the bulb and then the opposite sides go into the two slots for either side of where the fuse was? :o
John
Put one wire to the body of the car, anything made of metal on the main structure will do, cars use the body (or earth) as negative.
Then put the other into the fuse slot. One of them should have 12v, the back one IIRC.
john-melbourne
Got a circuit tester and tried that, tried it on a circuit i knew worked which was the hazards, and it lit up brightly, then when onto number one fuse and it lit up but was very dim?
John
