jas-E 1 Posted April 15, 2008 Part numbers and prices for Mi16 uprated Oil Pressure Upgrade Oil Pump Spring - 1157 11 - £1.56 52 Link Chain - 1033 10 - £21.12 Sprocket - 0513 54 - £4.32 + VAT I believe these are XU10 components used to upgrade XU9 ones 1 Share this post Link to post Share on other sites
Simes 248 2 Cars Posted April 15, 2008 Aerial base and aerial 971635 £9.15 +VAT Share this post Link to post Share on other sites
Baz 421 Posted April 15, 2008 Aerial base and aerial 971635 £9.15 +VAT Is that the long or later shorter aerial Simes? Share this post Link to post Share on other sites
petesy71 0 Posted April 27, 2008 971614 - aerial base alone £4.41 +vat 699444 - side door fix (trim kit mentioned above by chrisj21, however only containing the clips for one side of the car), was £21.98 last august, now £24.22 +vat 222132 - casing plug (gearbox drain plug) £1.18 +vat 698842 - plug seal (gearbox filler washers x10) £2.80 986099 - paint aerosol (sorrento green aerosol & lacquer) £6.47 986257 - varn paint pen (sorrento green touch up pen) £3.76 Share this post Link to post Share on other sites
chrisj21 2 Posted April 27, 2008 699444 - side door fix (trim kit mentioned above by chrisj21, however only containing the clips for one side of the car), was £21.98 last august, now £24.22 +vat This is a complete car kit as i fitted mine this weekend and had all parts. Chris Share this post Link to post Share on other sites
petesy71 0 Posted April 27, 2008 699444 - side door fix (trim kit mentioned above by chrisj21, however only containing the clips for one side of the car), was £21.98 last august, now £24.22 +vat This is a complete car kit as i fitted mine this weekend and had all parts. Chris hi chris, i removed my trim last week and found i only had enough kit to do one side, so had to order another and picked it up on saturday. its the same part number, i'll post a pic of everything contained in it tomorrow. Share this post Link to post Share on other sites
petesy71 0 Posted April 28, 2008 i checked all the bits of the kit today and there was definately only enough for the one side. i laid out the parts as they had come off the car and there were some spares, but not enough for both sides, especially for key items like the metal spring clips of which there were only six,(six came off the one side, all were rotten bar one).i took a couple of pics. Share this post Link to post Share on other sites
Guest new2gti Posted April 29, 2008 Hi guys need a part number for a fuel pressure regulator for a 1.9 gti. Skimmed the thread but there is so many parts listed here i couldn't find it. Share this post Link to post Share on other sites
Ryan 99 Posted April 29, 2008 Hi guys need a part number for a fuel pressure regulator for a 1.9 gti. Skimmed the thread but there is so many parts listed here i couldn't find it. 1563 99. It's a bit pricey at £80.29 though. Share this post Link to post Share on other sites
Guest new2gti Posted April 29, 2008 Thanks man, why so expensive? Share this post Link to post Share on other sites
welshpug 1,722 Posted April 29, 2008 probably because they dont sell many, best off finding a bosch/lucas dealer for that. Share this post Link to post Share on other sites
Guest new2gti Posted May 2, 2008 is this not the right part for the gti. I ask this because the last 2 digits of the part number are different? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=110247543234 thanks Share this post Link to post Share on other sites
Ryan 99 Posted May 2, 2008 That's a 2.5 bar regulator. The GTI uses a 3 bar. Share this post Link to post Share on other sites
dale205mills 39 7 Cars Posted May 2, 2008 I've just had aload of price's done for parts for my 205, Sunroof skin 810191 has gone up to £152.06 Red carpet 758375 is £392.97 Roof headling 8326v5 £201.98 Front subframe 3502a2 £540.51 Air intake gril 825127 £132.74 All the parts, I asked about came £1278.35 Share this post Link to post Share on other sites
reuben205 0 Posted May 4, 2008 anyonegot a part numbers and price for sad valve please? Share this post Link to post Share on other sites
jord294 97 Posted May 4, 2008 aint got the part number to hand. but when i asked the other day they were £102 + vat 2 Share this post Link to post Share on other sites
Simes 248 2 Cars Posted May 8, 2008 One I couldn't find on service box Ignition Amplifier (8v & 16v) £71.48 + VAT 5945 48 Share this post Link to post Share on other sites
Ricardo 0 Posted May 11, 2008 1.6 GTi Fuel line/filter seals (Banjo copper rings + Olive) ex vat. 156236 Gland-F. Pipe 0.32 156244 Seal-Fuel Pipe 0.24 156245 Seal-Fuel Pipe 0.34 156256 Seal-Fuel Pipe 0.69 The bottom filter seals are only sold in bags of 10 off and 20 off but the sales guy was good enough to split. Share this post Link to post Share on other sites
marksorrento205 80 Posted May 29, 2008 MI16 engine parts 32622 small crankshaft oil seal £9.28 12728 large crankshaft oil seal £12.14 12705 crankshaft bearing seals ( golf club ones as pug called them) £0.72 ea 081640 Timing belt £29.24 082920 Tension roller £37.30 ea 0348G4 Inlet manifold gasket £2.59 ea 0349E8 Exhaust manifold gasket £13.65 118045 Oil fill pipe from the filler to the block £29.65 025837 Oil fill cap £21.92 117824 Oil fill breather £14.07 1.6 gti engine parts 030434 Sump gasket dont know the price 1.9 gti parts 1992 (if it matters) 480652 Rear brake flexi hose that goes to the caliper - same part no for both sides £13.88 All plus VAT Share this post Link to post Share on other sites
Goliath 94 Posted May 29, 2008 FRONT PANELS (behind the headlights): LH panel 7113 51 £63.94 RH panel 7114 52 £64.07 Whole front panel is £51 from my local panel place so I will be getting mine there not from pug! WINGS (outer): 7840 73 £91.42 each INNER WINGS: 7121 82 £43.40 Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted July 7, 2008 1.9 GTi handbrake cables; 4745 67 LH 4745 68 RH £8.89 each + vat Bumpstop (inc cap & bolt); 5166 28 £6.81 each + vat. Graham. Share this post Link to post Share on other sites
CaptainK 11 Posted July 8, 2008 A lambda probe for a 1997 2L 16v GTi6 engine costs £145.35 inc vat (£123.70 + vat) Peugeot part number P000016289S ZZZ Oxygen Probe. Share this post Link to post Share on other sites
Chaff 0 Posted November 2, 2008 GTi 1.6 after market alternator £64.78 Bennetts Share this post Link to post Share on other sites
Chris_Mi 6 Posted December 16, 2008 Hi anybody know what has happened to Servicebox? For some reason it will no longer give me a price for items, instead it just gives me a box requiring me to fill out my name, address etc. This never happened before, it just gave me the price when I clicked on the basket. What's happened ??? Share this post Link to post Share on other sites
Ryan 99 Posted December 16, 2008 Hi anybody know what has happened to Servicebox? For some reason it will no longer give me a price for items, instead it just gives me a box requiring me to fill out my name, address etc. This never happened before, it just gave me the price when I clicked on the basket. What's happened ??? I got that earlier today. I just clicked on the basket again and it went to the price list. Share this post Link to post Share on other sites
