TaffyTim
How To Undo The 19mm Nut
TaffyTim
Having found the correct nut on the gearbox to top up the oil, i now need to get it off.
Im pulling at it with alot of force to try and undo this nut with a socket and its not budging!!!
Any tips?
Normski
More leverage, use a big swan neck ring spanner on the end of the ratchet or a deep 17 or 19 mm socket with an extention bar.
lefty loosy righyty tighty ;) sure its the right one?
g60-r
Get your self a long power bar. i.e a long bar to go on your socket. about £20 from a local tool seller. careful the socket doesn't slip or it will round the nut and you'll be buggered ;) . to avoid this you can get a 6 sided socket from halfrauds, they call it an impact socket, there black and about £6-7. you'll sheer the bolt before these slip.
Faling that a gentle bit of heat around the nut area and shed loads of wd40 :)
Failing that a bloody big sledge hammer :D
TaffyTim
:):D:D:D
Not guilty of this this time, i like the saying though :D
TaffyTim
ok back to halfauds tomorrow then as its starting to slightly round now.
TaffyTim
Just need to confirm for my sanity that this is the right nut:
thats the bugger! should have a copper washer under it meaning it "shouldnt " be that tight, I'm guessing its not there though and someone has whacked it up tight.
TaffyTim
ta welshpug.
hengti
probably not a good idea if it has started rounding, but you can start most large nuts/bolts by clobbering the ratchet handle with a meaty hammer
ps. you want to be pushing and not pulling on that one ;)
Edited by hengti
sonofsam
^Does work, but at the cost of maybe buggering the ratchet mech, especially if it's a cheap 'un.
Speaks from experience ;)
Try wedging some tin foil round the bolt head before you put the socket back on to act as a shim.
Edited by sonofsam
rattle gun! new copper washer and a torque wrench ;)
kate205gti
scaffold pole ;) :innocent:
taylorspug
Ive had a few of these go tight before, if i really cant undo them easily just by hand, a sharp crack with a hammer on the ratchet/spanner does the trick. Make sure you hold the socket 'against' the slack on the bolt (ie push the ratchet in the right direction before you hit it!), as otherwise the bolt has more chance of rounding off. ;)
dont whack the ratchet!
taylorspug
Balls to it, if it gets the bolt undone, il give anything a good clout! :):D;)
hengti
whack the ratchet! :D
you'd be better off using a good ring spanner though - preferrably a swan-necked one
Alastairh
Grow some muscle!
Ahl
Its quite a shallow head on that one isn't it?
I think I used an impact driver to loosen one off before.
taylorspug
Yes the head is shallow, hence if you just keep pulling and pulling on it, its likely to round off or shear. A good crack will shock it loose and save completely ruining the bolt.
Impact driver would certainly also work!
TaffyTim
Im liking the technical approaches suggested above :D
Ive put a letre of oil in through the breather at the top and when the car is jacked and a wheel is turned the nasty noise has gone away :(
Are these pics of the my breather looking good, all it is is a plastic nut with a hole in it!! is it missing something?
Unfortunately Ive got a worse sounding noise which really doesnt sound good.
Ive started a new thread which includes this noise, come and have a listen.
http://forum.205gtidrivers.com/index.php?showtopic=74237
Yup that's how that should look, although should have a bung in the top, not too drastic if it's gone missing really though.
Is that hole there really for a would be reverse lockout cable or something though?
yep.
TaffyTim
Ruber bung Hmmmmmmmmmmm
It wouldnt happen to look like the rubber bung thats horrizontally through the hole in the side of the spedo cable in the pic below?
