Spiky
Best Spark Plugs? And Gap
Spiky
tried a search, but nothing much
whats the best spark plug to use???
and whats the perfect gap?
Faz85
For a 1.9 - NGK everytime. BCPR7ES IIRC
Faz
yorkshirekowboy
Faz
i use BCPR6E for my 1.9, ACE!!!!! thou i jusT got some new ones got given BCPR6ES... juts notcied now
wonder if theres any diff between the two? :wacko:
hengti
the platinum equivalent (EVX i think) is good in the std 1.9; v expensive though
i've only ever used the std gap (31thou)
yorkshirekowboy
Andrwn8304
The 6 and 7 numbers are the heat range for the spark plug.
The plug gap should be 0.7 mm - 0.8 mm 28000 to 30000 I would recommend the 0.7 mm as this saves on the strength of the HT from the coil pack.
You can use either just different manufacturers come up with different designs to improve performance.
I use Bosch Platinum in mine, sry not sure on the numbers now.
Heres the Champion numbers with the NGK cross reference :-
(Champion) - RC7YCC - (NGK) - BCPR7ES
Edited by Andrwn8304
yorkshirekowboy
so the NGK - BCPR7ES are better than the BCPR6E? dont like champion, find them very expensive for what they are, and always had problems with them!!!
Andrwn8304
or the BCPR7E there a slightly hotter plug but designed for the Pugs
yorkshirekowboy
so if i got the BCPR7E, would i see a difference in performance from the BCPR6E,S
also would the BCPR7E damage my engine?
Andrwn8304
The performance difference would be so small you wouldnt notice it.
Absolutely not they are the plugs listed for your car.
Spiky
i think i got BKR6EZ
so maybe i'll change to BCPR7E and gap to 0.7
Faz85
IIRC, the "6" rated plugs are the recommended NGKs if you have a catalytic converter. Before doing away with my CAT, I was running BCPR6ES. I switched to 7ES, and there was no noticeable difference really, so its entirely up to you. Either 6 or 7 plugs wont cause you any problems.
Faz
yorkshirekowboy
Faz
i may take back the BCPR6ES I was given back and try a set of BCPR7E, if they dont have any of them i will try the same but ES version :angry:
ace
wonder if i notcie the diff as my leads are proper old and my cap is and the sparks been on a year now, notcied my car is getting slugish, so trying this, normally works!!!! :angry:
still looking for some leads, i hate bosch leads, always come apart, so looking at ebay now........
wish me luck
saveloy
What you really want is a set of NGK BCP7EV plugs, gapped to 0.9mm, and I mean it. Bingo.
richard
good choice Saveloy. This is the same gap as i.
Spiky
where do you guys buy these plug?
NGK BCP7EV
any local motor factors? or on the net? or pug dealers?
any idea on rough price
309PUG
Just to confuse you even more, I use BOSCH FR7DC+8 recommended by AB Motorsport, thats all they use. Spot on for me, I think Halfrauds even sell them make sure you get the +8 though.
Chris
Andrwn8304
I think bottom line is m8 everyone has there own preferences.
If in doubt ask your local motor factor for the top spec plug for your car.
hengti
NGK BCP7EV
they're OE for some Saabs - you might be able to find them at Motorfactors
expensive though - i think £25 for the last set i bought
yorkshirekowboy
:o
Spiky
well my motor factors dont sell BCP7EV nor can they get them
so will try halfords next
if not ebay sell them at around £5-£6 each
Edited by Spiky
saveloy
My local Halfords stock them. Excellent plugs, I used them on my TT for years. They are a projected core design, which means the spark is closer to the chamber centre. So, aiding combustion.
It is even worth gapping them to 1mm first and seeing if the engine runs with no mis - fires.
Edited by saveloy
pugrallye
The heat range is the operating temperature of the spark plug and environment, in an XU engine you wont really notice the differences in ranges, (only really noticeable in high output/ high stressed engines) just remember doing a customers car with poor cold starting and running, and it was down to someone fitting incorrect heat range plugs!
Craigb
excuse my ignorance , but what is the benefit of the larger gap ?
Edited by Craigb
