Spiky
[trackday_prep] My 205 GTI-6 Supercharged Track Car
Spiky
tombo, you''ll be no6 then :(
so you buying a pug or taking the clio on track?
SteveW
You getting another 205 Tom?
tombo
well it has been in serious consideration.... the old man wants to go halfs on a track car, he really wants a caterham/westfield type option, im trying to talk the 205 efforts into him with affordable track day fun being the strongest point.
hmmmm i may need all your assitance to get this to happen, im thinking possibly a miami blue gti?
Spiky
well been a while since i did and update, few little changes :)
took the engine out to change the gearbox back the 1.9 and change clutch
though after i took the clutch off, i found it was brand new, so didnt bother
first of all i sold all my light C5 steelie wheels,
so far i have bought 2 sets of replacements
set 1
set 2
the main reason for the change, is for a slight change of calipers that i'm trying
need to get some decent pads but will use whats in there for now
i have bought a new steering wheel, as i thought the car deserved one :), so bought this
also decided that innacurate speedo just doesn't do it, so have decided to ditch the standard clocks and the SPA gauges
and bought a stack dash :D , got a it for a good price and it's the 8310P so does pretty much everything
oil temp, oil pressure, water temp, fuel level, fuel pressure, oddometer and various other features :)
so i have bought some carbon fibre to mount it, but here is a trial mockup useing cardboard
you think thats enought?
well no..lol
one last update to all that :D
i have sold the ITB's and DTA ecu :( bye bye sound :(
and bought this setup :D
all hoses and silicone will be going black (awaiting deleivery )
can fit the panel back on to, so it's kinda back to standard :)
Edited by Spiky
Spiky
what ya think ? :D
Batfink
I think you are going to have some serious fun :lol:
I've just got a digi dash myself. They make sense once you look at the full cost of buying multiple high quality dials
oli-pug
What do I think?? It's brilliant and I'm jealous :P
Spiky
Should be a laugh lol
One complete dash just makes sense, ESP as this does everything
309PUG
Hi,
That's the same dash I had, great bit of kit, what management will you be running ??
Chris
Spiky
Yeah ,always wanted one :)
It will be using a standard gti6 ecu
oli-pug
Surprised you didn't keep the DTA to run it to be honest, I know Rich does the ready mapped ecu's for low boost but every engines different at the end of the day :huh:
projectpug
Looking very good Spiky. We are now using the same front elise brakes. I am using padgid ceramic pads with mine i highly rate them although they are circa £150 a set. What ET are the wheels your using iirc the elise brakes require a 12mm spacer for clearance. Im looking into some alloy belled disks for the elises as the only thing that lets them down imo is the weight of the hdi disc.
Spiky
Would have been ideal, but needed to get back as much as I could to fund the sc conversion
oli-pug
Ahh fair enough, should still go like the clappers! B)
Any plans to beef up the drivetrain? I think Garry had trouble with his driveshafts and now runs modified 306 ones.
Spiky
Both wheels have good caliper clearance, so hoping I don't need spacers, not tried them yet, do that on the weekend
Undecided on pads for now
As my engine sits at correct angle and most of the 306 guys have little issues, I'm hoping I should be ok for a while, else I will look at sorting it :)
The inlet is the same as a 306 so it gives you an idea how much angle changing does :)
oli-pug
Yeh hopefully they'll be ok then, if they're decent quality shafts to start with I'm sure with mechanical sympathy they'll last.
Hoping to get over to do a few more Combe trackdays this year, plus I like the look of Pembrey! You got any booked?
Spiky
No plans yet, just trying to find time to get it finished
Just had twins so time isn't on my side lol
Pembrey is ok, was a little disappointed, as I thought it was bigger, bigger than landow, and would do again :)
james28
just seen all the work gone into this car its awesome and the car certainly goes well
where can i get a diff from for my gti spiky ? and was it expensive.
Spiky
todays progress
fitted dash
fitted the MOT requirements lights
fitted AFR gauge, though due to wheel, slightly hidden but can still see it
and fitted the switchs for the stack
also fitted replace hub and fitted all the brakes on
http://smg.photobucket.com/albums/0603/spikysteve/205-11/?action=view&current=IMG_0907.mp4
SteveW
Looks really cool that fair play
james28
as said that looks ace :)
Spiky
did you click the video below the picture? :D
like a kid at christmas..lol
james, i bought my diff second (but was unused) but rallydesign, and several places sell them, for around 600'ish
james28
does the diff make a big differance? before and after the cars are quite nimble and grip well.Thought about this on mine but i am only a novice track day driver been to snetterton a few times donnington a few times and mallory.
Spiky
Depend how you drive, if you drive like miss daisy it probably won't make much difference, I certainly noticed the extra grip :)
hatemgti
what gearbox you are going to use with this new setup?
